undertray problems
OllieL
2.0 16v Cupra Sport GTi
Dec 10, 2006
1,868
Birmingham
I have just got back in from messing about with the poxy undertray under my car.
It must have come loose on my way home and then became caught by the nearside front wheel when entering a roundabout.
It got wrapped around my wheel and arch lining and then dragged down the road..
Mine is looking a bit worse for ware, so am thinking of replacing it. I managed to hook it up and limp home, but need to see if I can re-attach it tomorrow
I know people say that they do nothing and to just take them off, but I think that the reason I haven't been plagued by some of the common 'wet weather' Ibiza problems is that the tray has kept my engine bay nice and dry.
Does anyone have the part number for the undertray??
Ollie
andyj
There's no F in Quality..
I do beleive you want this part:
3 6K0825235
sound deadener
/ ABF,ALM,AEE, ANX,AER,ADZ, 1F,APQ
from this diagram:
OllieL
Dec 10, 2006
1,868
Birmingham
Well I am very attached to mine, well I was before it fell off.
Need a fixing kit apparently too.
Anyone know the number as clarkes are worse than useless
Ollie
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
do you need all of them as some are nuts over studs (that break off) and others are bolts into captive nuts (again sieze and break off)
OllieL
Dec 10, 2006
1,868
Birmingham
Seat want £1 per fixing.
Think I will wait to get it over my mates pit and see if I can fix it up more securely without.
Ollie
sosidge
Newbie
Jun 5, 2004
65
Most annoying thing about the undertray (on all cars I've owned) is that I don't think there is a single garage out there that takes the time to remove and re-attach them properly. They just pull at them until the fixings pop off or break, then just tuck them in around the bumper once they've finished.
A week later you wonder what that grinding noise is over the bumps...
Jun 14, 2005
920
Northants.
Ollie
Mine was destroyed when the garage changing the cambelt omitted three of the fixings when refitting causing it to drop down at 70mph!!!
So I bought one of these:
http://cgi.ebay.co.uk/ws/eBayISAPI....em=&sspagename=STRK:MEWAX:IT&salenotsupported
I think they are about £150 from the dealer!!!
Exactly the same as the original (99MY AGG 8v) and has a hole in the NS for the end of the gearbox (the blank with VW pressed in) to poke through! Got to be the same on both 8v and 16v!
DC
3,476
Telford ay it...
DC
Does that under tray fit bob on? There's still a couple available.
suj
Wheel Connoisseur
Jan 1, 2009
5,808
Birmingham
Cheers for the quick one mate, going to consider one for the hack. Probably make minimal difference but it must reduce drag.
hey jenk, wouldn't it be better without one for cooling purposes for your track hack?
as the heat would have less to radiate to? :confused:
i might buy one of them tho, thanks DC :D
Dolly_Gti
G60 spooling up.
Aug 15, 2006
1,412
china town
ive got one mate, think it must of caught a pulley its got a small hole/rub mark on the side of the engine pulleys, apart from that its very good condition, can have it if its any use?
