Under Perfoming Cupra - Problem Identified
Al
7,331
9
Thanks Rob, those furry intake valves you spoke to me about are a worry. A damaged intercooler has been mentioned as well.
I have decide to go see the VAG master tech at REVO so he can have a good once over and hopefully put his finger on the problem
Going by your logs, there is no evidence of boost drop/loss which is what you would see with a damaged intercooler. I would be more concerned that the requested boost is not what Revo say it should be.
Dec 2, 2008
571
Nottingham
If Revo say this should be pulling 1.4 Bar of boost, note that the requested boost is only 1.2 Bar which is being met.
What happens when you run the car with the MAF connected?
Log above is with MAF connected. I havent posted the one with MAF disconnected as it is very similar to my 'untrained' eye
Requested is 1.2 and actual is 1.2 with MAF disconned
Monster may have tinkered with the setting to stop it running in det before it is looked at, but I'm no expert on these matters.
That's probably why the B/T/F settings are a little strange
MAF Disconned log;
Code:
	Cyl 1 Ign	Cyl 2 Ign	Cyl 3 Ign	Cyl 4 Ign		Eng Spd	Eng Load	Bst Pres	Bst Pres		Rail Pres	Rail Pres	Rail Pres
TIME	Ang Dly	Ang Dly	Ang Dly	Ang Dly	TIME			(specif)	(actual)	TIME	(specif)	(actual)	Diff
STAMP	°KW	°KW	°KW	°KW	STAMP	 /min	 %	 mbar	 mbar	STAMP	 bar	 bar	 bar
0.32	0	0	0	0	0.07	3160	16.5	290	1040	0.2	87.05	86.63	0.42
0.71	0	0	0	0	0.46	3200	68.4	1900	1000	0.59	104.05	109.67	-5.62
1.1	0	0	0	0	0.83	3240	100	2200	1290	0.98	121.16	121.98	-0.82
1.49	0	-3	0	0	1.23	3360	152.6	2200	1910	1.35	124.47	124.3	0.17
1.86	0	-3	0	0	1.62	3520	186.5	2200	2200	1.74	125.04	124.76	0.28
2.25	0	-3	0	0	2.01	3720	191.7	2190	2340	2.13	125.49	125.12	0.36
2.64	0	-3	0	0	2.38	3880	191	2190	2200	2.52	125.9	124.72	1.18
3.03	0	-3	0	0	2.77	4040	185.7	2200	2160	2.89	126.32	124.49	1.83
3.41	0	-3	0	0	3.16	4200	182	2210	2160	3.29	126.72	125.78	0.94
3.8	0	-3	0	0	3.55	4360	184.2	2230	2190	3.67	127.14	127.52	-0.38
4.19	0	-2.3	0	0	3.92	4520	183.5	2240	2200	4.07	127.43	126.41	1.02
4.58	0	-2.3	0	0	4.31	4680	185.7	2230	2210	4.44	127.48	127.92	-0.44
4.95	0	-2.3	0	0	4.7	4840	186.5	2230	2230	4.83	127.49	125.47	2.02
5.34	0	-2.3	0	0	5.1	5000	186.5	2230	2210	5.22	127.49	126.82	0.67
5.73	0	-2.3	0	0	5.47	5120	187.2	2230	2220	5.61	127.49	126.34	1.15
6.12	0	-2.3	0	0	5.86	5280	186.5	2230	2210	5.98	127.49	127.62	-0.13
6.5	0	-2.3	0	0	6.25	5440	185	2230	2190	6.38	127.49	125.92	1.57
6.89	0	-2.3	0	0	6.64	5560	187.2	2230	2210	6.77	127.49	128.04	-0.55
7.28	0	-2.3	0	0	7.01	5680	186.5	2230	2200	7.15	127.49	127.63	-0.14
7.67	0	-1.5	0	0	7.4	5840	187.2	2240	2210	7.53	127.49	129.69	-2.2
8.04	0	-1.5	0	0	7.79	5960	189.5	2170	2210	7.92	127.49	126.57	0.92
8.44	0	-1.5	0	0	8.18	6080	191.7	2150	2170	8.31	127.49	124.49	3
8.82	0	-1.5	0	0	8.56	6160	186.5	2150	2120	8.7	127.49	124.89	2.6
9.21	0	0	0	0	8.95	6200	49.6	600	1910	9.07	99.38	117.73	-18.36
9.59	0	0	0	0	9.34	6120	16.5	290	1270	9.46	94.82	122.08	-27.26
9.98	0	0	0	0	9.73	6000	17.3	290	1170	9.85	90.93	113.84	-22.91
10.36	0	0	0	0	10.1	5840	17.3	290	1140	10.24	102.17	102.17	0
10.76	0	0	0	0	10.49	5600	17.3	290	1110	10.62	102.22	102.22	0
11.13	0	0	0	0	10.88	5360	18	290	1100	11	103.19	103.19	0
11.52	0	0	0	0	11.28	5120	17.3	290	1110	11.4	104.13	104.13	0
11.91	0	0	0	0	11.65	5000	16.5	290	1100	11.79	104.85	104.85	0
12.3	0	0	0	0	12.03	4800	16.5	290	1090	12.16	105.55	105.55	0
12.67	0	0	0	0	12.43	4680	16.5	290	1090	12.55	106.12	106.12	0
13.07	0	0	0	0	12.82	4560	16.5	290	1080	12.94	106.82	106.82	0
13.45	0	0	0	0	13.19	4480	16.5	290	1080	13.34	107.3	107.3	0
13.84	0	0	0	0	13.58	4400	16.5	290	1070	13.7	107.79	107.79	0
14.22	0	0	0	0	13.97	4320	16.5	290	1080	14.09	108.24	108.24	0
14.61	0	0	0	0	14.36	4240	16.5	290	1080	14.48	108.72	108.72	0
15	0	0	0	0	14.73	4160	16.5	290	1080	14.88	109.05	109.05	0
15.39	0	0	0	0	15.12	4120	16.5	290	1080	15.25	109.43	109.43	0
15.76	0	0	0	0	15.51	4040	16.5	290	1080	15.64	109.78	109.78	0
16.16	0	0	0	0	15.91	4000	16.5	290	1080	16.03	110.03	110.03	0
96.48	0	0	0	0	96.23	1920	90.2	1230	1270	96.35	109.15	108.2	0.95
96.87	0	0	0	0	96.6	2000	100.8	1770	1320	96.74	120.97	121.51	-0.54
97.26	0	0	0	0	96.99	2120	112.8	1890	1420	97.12	124.45	124.23	0.22
97.63	0	0	0	0	97.38	2240	123.3	2080	1560	97.51	124.92	123.52	1.4
98.02	0	0	0	0	97.77	2400	137.6	2130	1730	97.9	124.98	124.69	0.29
98.42	0	0	0	0	98.15	2520	153.4	2170	1930	98.29	124.99	123.38	1.61
98.81	0	0	0	0	98.54	2680	174.4	2190	2180	98.67	124.99	126.1	-1.11
99.18	0	0	0	0	98.93	2880	191.7	2190	2370	99.05	124.99	125.94	-0.95
99.57	0	0	0	0	99.32	3040	191.7	2190	2370	99.44	124.99	123.42	1.57
99.96	0	0	0	0	99.69	3240	191.7	2190	2300	99.83	124.99	125.98	-0.99
100.35	0	0	0	0	100.08	3400	187.2	2200	2200	100.21	124.99	125.16	-0.17
100.72	0	-3	0	0	100.47	3560	187.2	2200	2180	100.6	125.2	125.77	-0.57
101.11	0	-3	0	0	100.86	3720	189.5	2190	2200	100.98	125.58	126.55	-0.97
101.5	0	-3	0	0	101.24	3880	188	2190	2200	101.38	125.97	124.89	1.08
101.89	0	-3	0	0	101.62	4040	185	2210	2180	101.75	126.36	125.3	1.05
102.27	0	-3	0	0	102.02	4200	182.7	2220	2170	102.14	126.73	125.67	1.06
102.66	0	-3	0	0	102.41	4360	184.2	2240	2210	102.53	127.11	126.44	0.66
103.05	0	-3	0	0	102.78	4480	183.5	2250	2210	102.92	127.42	124.57	2.85
103.44	0	-2.3	0	0	103.18	4640	185.7	2240	2220	103.29	127.48	127.71	-0.23
103.81	0	-2.3	0	0	103.56	4800	185	2230	2230	103.69	127.49	126.7	0.79
104.2	0	-2.3	0	0	103.95	4920	185.7	2250	2220	104.08	127.49	127.35	0.14
104.59	0	-2.3	0	0	104.32	5040	187.2	2240	2240	104.47	127.49	125.82	1.67
104.98	0	-2.3	0	0	104.72	5200	187.2	2240	2220	104.84	127.49	127.37	0.12
105.35	0	-2.3	0	0	105.1	5320	187.2	2240	2220	105.23	127.49	126.34	1.15
105.74	0	-2.3	0	0	105.5	5440	185.7	2240	2210	105.62	127.49	128	-0.51
106.14	0	-2.3	0	0	105.87	5560	186.5	2250	2210	106.02	127.49	127.26	0.23
106.53	0	-2.3	0	0	106.26	5680	188	2250	2230	106.39	127.49	126.56	0.93
106.9	0	-1.5	0	0	106.65	5800	188	2250	2230	106.78	127.49	128.37	-0.88
107.29	0	-1.5	0	0	107.04	5920	188.7	2200	2230	107.17	127.49	125.95	1.54
107.68	0	-1.5	0	0	107.42	6040	190.2	2170	2190	107.56	127.49	127.84	-0.35
108.07	0	-1.5	0	0	107.8	6120	188.7	2160	2150	107.93	127.49	128.73	-1.24
108.45	0	-1.5	0	0	108.19	6240	188	2170	2140	108.32	127.49	125.35	2.14
108.83	-0.8	-0.8	-0.8	-0.8	108.58	6360	188	1970	2140	108.71	124.96	124.45	0.51
109.23	0	0	0	0	108.96	6600	14.3	290	1610	109.1	122.28	122.28	0
109.61	0	0	0	0	109.35	5800	17.3	290	1220	109.47	125.37	125.37	0
109.99	0	0	0	0	109.74	4720	18.8	290	1170	109.86	118.53	121.52	-2.99
110.38	0	0	0	0	110.13	3920	16.5	300	1150	110.25	115.29	116.27	-0.98
110.77	-0.8	-0.8	-0.8	-0.8	110.5	3920	29.3	460	1120	110.65	110.24	111.67	-1.43
111.16	0	0	0	0	110.89	3880	30.1	480	1140	111.02	104.83	106.24	-1.42
111.53	0	0	0	0	111.29	3880	33.8	580	1160	111.41	100.96	101.84	-0.88
111.92	0	0	0	0	111.68	3840	47.4	670	1250	111.8	104.11	104.82	-0.71
112.31	0	0	0	0	112.05	3840	46.6	680	1320	112.19	104.41	104.42	-0.02
112.7	0	0	0	0	112.44	3800	46.6	680	1340	112.56	104.4	105.72	-1.32
113.08	0	0	0	0	112.83	3800	46.6	680	1340	112.95	104.38	102.6	1.78
113.46	0	0	0	0	113.22	3800	47.4	680	1350	113.34	102.88	102.52	0.36
113.86	0	0	0	0	113.59	3760	15.8	290	1230	113.73	98.88	95.87	3.01
114.25	0	0	0	0	113.98	3720	15.8	290	1120	114.11	96.33	94.82	1.51
114.62	0	0	0	0	114.37	3680	16.5	290	1080	114.5	94.61	94.61	0
115.01	0	0	0	0	114.76	3640	16.5	300	1070	114.89	95.32	95.32	0
115.4	0	0	0	0	115.14	3600	16.5	290	1060	115.28	94.18	95.88	-1.7
115.79	0	0	0	0	115.53	3600	16.5	290	1070	115.65	90.08	90.13	-0.05
116.17	0	0	0	0	115.92	3560	18.8	330	1060	116.04	87.19	87.08	0.11
116.56	0	0	0	0	116.31	3560	19.5	340	1060	116.43	83.71	83.34	0.37
116.95	0	0	0	0	116.68	3520	20.3	340	1060	116.82	80.36	80.06	0.3
117.34	0	0	0	0	117.07	3480	21.1	360	1060	117.19	77.09	77.25	-0.16
117.71	0	0	0	0	117.46	3440	21.1	360	1070	117.58	73.75	74.14	-0.39
118.1	0	0	0	0	117.85	3440	21.1	360	1070	117.97	70.42	69.18	1.23
118.49	0	0	0	0	118.22	3400	16.5	300	1070	118.37	67.59	67.03	0.55
118.88	0	0	0	0	118.61	3360	16.5	300	1060	118.74	65.25	65.32	-0.07
119.25	0	0	0	0	119	3360	16.5	300	1060	119.13	64.98	64.98	0
119.65	0	0	0	0	119.39	3320	16.5	300	1060	119.52	65.61	65.61	0
robdf2
Yellow is the best
Feb 21, 2006
3,605
location , location
Heres my log on standard car , as you can see my timing pull is errmmmm massive and SEAT say its ok ffs !
just out of interest what should standard boost be?
Code:
		G001	G020	G020	G020	G020	G114	G115	G115	G230	G230	G230
Marker	TIME	Group 1 - Field 0	Group 20 - Field 0	Group 20 - Field 1	Group 20 - Field 2	Group 20 - Field 3	Group 114 - Field 3	Group 115 - Field 2	Group 115 - Field 3	Group 230 - Field 0	Group 230 - Field 1	Group 230 - Field 2
	STAMP	Engine Speed	Cylinder 1 Ignition - Angle Delay	Cylinder 2 Ignition - Angle Delay	Cylinder 3 Ignition - Angle Delay	Cylinder 4 Ignition - Angle Delay	Wastegate (N75) - Duty Cycle	Boost Pressure - (specified)	Boost Pressure - (actual)	Rail Pressure - (specified)	Rail Pressure - (actual)	Rail Pressure - Difference
		 /min	°KW	°KW	°KW	°KW	 %	 mbar	 mbar	 bar	 bar	 bar
	0.04	1080	0	0	0	0	0	850	1010	63.14	61.94	1.2
	0.3	1080	0	0	0	0	94.9	1370	1000	65.29	66.09	-0.8
	0.54	1120	0	0	0	0	94.9	1350	1010	67.1	67.94	-0.85
	0.82	1200	0	0	0	0	94.9	1380	1030	69.21	69.27	-0.06
	1.06	1280	-2.3	0	0	0	94.9	1430	1050	71.15	71.48	-0.33
	1.33	1360	-2.3	0	0	0	94.9	1460	1070	73.41	73.26	0.14
	1.58	1440	-2.3	0	-2.3	0	94.9	1500	1090	75.84	75.7	0.14
	1.85	1560	-2.3	0	-4.5	-2.3	94.9	1530	1130	78.38	77.99	0.38
	2.1	1640	-4.5	-2.3	-4.5	-2.3	94.9	1570	1170	80.83	80.74	0.09
	2.35	1760	-4.5	-2.3	-4.5	-2.3	94.9	1620	1210	83.63	83.35	0.28
	2.6	1840	-4.5	-2.3	-4.5	-2.3	94.9	1710	1250	86.4	86.05	0.35
	2.85	1960	-4.5	-2.3	-4.5	-2.3	94.9	1790	1290	89.62	89.42	0.19
	3.08	2080	-4.5	-2.3	-4.5	-2.3	94.9	1810	1340	92.7	92.58	0.11
	3.32	2200	-4.5	-2.3	-4.5	-2.3	94.9	1830	1410	96.17	96.18	-0.01
	3.59	2360	-6	-2.3	-4.5	-2.3	90.6	1820	1500	99.67	98.45	1.22
	3.84	2480	-6	-2.3	-4.5	-2.3	49	1820	1600	103.14	103.53	-0.39
	4.11	2640	-6	-2.3	-4.5	-2.3	42.7	1820	1700	106.5	106.9	-0.4
	4.36	2800	-6	-2.3	-3.8	-4.5	43.9	1810	1760	109.03	108.38	0.65
	4.62	3000	-6	-1.5	-3.8	-4.5	40.4	1800	1800	109.72	110.2	-0.48
	4.86	3160	-6	-1.5	-3.8	-4.5	41.2	1780	1830	109.92	110.09	-0.17
	5.12	3320	-6	-1.5	-3.8	-4.5	39.6	1770	1830	109.97	109.68	0.29
	5.37	3480	-6	-1.5	-3.8	-4.5	37.6	1760	1780	109.99	109.76	0.23
	5.64	3640	-0.8	0	0	-0.8	37.6	1760	1740	109.99	109.8	0.19
	5.87	3840	0	0	0	-0.8	38.4	1760	1720	109.99	109.37	0.62
	6.14	3960	0	0	0	-0.8	39.2	1780	1720	109.99	110.09	-0.1
	6.37	4120	0	0	0	-0.8	41.2	1810	1750	109.99	108.95	1.04
	6.63	4280	0	0	0	-0.8	42.7	1830	1780	109.99	109.15	0.84
	6.87	4440	0	0	0	0	43.9	1840	1790	109.99	109.79	0.2
	7.13	4600	0	0	0	0	44.7	1850	1810	109.99	109.57	0.42
	7.38	4760	0	0	0	0	45.1	1870	1810	109.99	109.82	0.17
	7.64	4920	0	0	0	0	46.3	1880	1830	109.99	109.46	0.53
	7.87	5040	0	0	0	0	46.7	1900	1860	109.99	108.51	1.48
	8.13	5200	0	0	0	0	47.5	1920	1860	109.99	109.08	0.91
	8.38	5360	0	0	0	0	48.6	1940	1860	109.99	110.35	-0.36
	8.64	5480	0	0	0	0	49.8	1930	1870	109.99	106.59	3.4
	8.89	5600	0	0	0	0	50.6	1900	1870	109.99	110.67	-0.68
	9.16	5760	0	0	0	0	51	1870	1860	109.99	112.99	-3
	9.41	5920	0	0	0	0	50.6	1800	1840	109.99	110.23	-0.24
	9.67	6040	0	0	0	0	49.4	1740	1790	109.99	112.87	-2.88
	9.93	6160	0	0	0	0	48.6	1720	1760	109.99	110.79	-0.8
	10.19	6280	0	0	0	0	47.8	1700	1730	109.99	106.62	3.37
	10.45	6440	0	0	0	0	47.5	1690	1710	109.99	110.4	-0.41
	10.72	6560	0	0	0	0	47.1	1650	1680	109.99	112.87	-2.88
	10.99	6640	0	0	0	0	42.4	1410	1650	109.99	111.56	-1.57
	11.25	6760	0	0	0	0	24.3	1280	1570	109.99	118.15	-8.16
	11.5	6840	0	0	0	0	22	1210	1480	109.99	113.35	-3.36
JMP
165
What fuel are you using to get this timing pull? Boost looks like what standard should be.
For the Invisible's car, It looks like its working fine. If revo says it should be requesting 1.4bar, it has got to have a wrong map in it. For example the boost settings cant even affect that much?
Al
7,331
9
Comparison from a boggo standard CDL code 2.0TFSi K04 :)
Code:
1P0 907 115 AB		2.0l R4/4V TFSI     0020
	Group A:	'115				Group B:	'002				Group C:	'020
		Engine Speed	Engine Load	Boost Pressure	Boost Pressure		Engine Speed	Engine Load	Injection Timing	Mass Air Flow		Timing Retardation	Timing Retardation	Timing Retardation	Timing Retardation
	TIME	(G28)		(specified)	(actual)	TIME	(G28)			Sensor (G70)	TIME	Cylinder 1	Cylinder 2	Cylinder 3	Cylinder 4
Marker	STAMP	 /min	 %	 mbar	 mbar	STAMP	 /min	 %	 ms	 g/s	STAMP	°KW	°KW	°KW	°KW
	0.14	0	100	250	1010	0.26	0	100	0	0	0.39	0	0	0	0
	42.65	1360	21.1	480	1010	42.41	1400	16.5	0.77	5.22	42.52	0	0	0	0
	43.05	1440	66.2	1460	1010	42.81	1400	24.8	2.04	9.14	42.93	0	0	0	0
	43.43	1560	84.2	1470	1040	43.17	1480	77.4	4.34	27.03	43.31	0	0	0	0
	43.84	1720	88.7	1520	1120	43.55	1600	87.2	4.34	33.11	43.68	0	0	0	0
	44.24	1880	94	1620	1200	43.96	1760	90.2	4.34	37.36	44.1	0	0	0	0
	44.63	2040	103	1730	1290	44.38	1920	96.2	4.59	42.67	44.5	0	0	0	0
	45.02	2240	113.5	1770	1410	44.75	2080	106	4.84	51.06	44.9	0	0	0	0
	45.41	2440	127.8	1770	1570	45.14	2320	117.3	5.1	63.47	45.27	0	0	0	0
	45.78	2680	138.3	1760	1720	45.53	2520	131.6	5.36	77.28	45.66	0	0	0	0
	46.17	2960	147.4	1750	1790	45.93	2800	141.4	5.61	87.75	46.05	0	0	0	0
	46.56	3240	148.9	1740	1760	46.3	3040	150.4	5.87	98.47	46.44	0	0	0	0
	46.96	3480	147.4	1730	1710	46.69	3280	148.9	5.61	104.42	46.81	0	0	0	0
	47.35	3720	146.6	1710	1710	47.08	3560	146.6	5.36	111.31	47.22	0	0	0	0
	47.73	3960	147.4	1720	1710	47.49	3800	145.9	5.1	118.25	47.61	0	-0.8	0	0
	48.12	4240	145.1	1730	1700	47.86	4080	145.1	5.1	126.14	48	0	-0.8	0	0
	48.52	4480	151.1	1750	1750	48.25	4400	147.4	5.1	139.81	48.37	0	0	0	0
	48.89	4720	148.9	1770	1740	48.64	4560	151.1	5.1	146.72	48.76	0	0	0	-2.3
	49.29	4960	147.4	1800	1740	49.05	4800	148.9	5.1	154.17	49.17	0	0	0	-2.3
	49.68	5120	150.4	1820	1760	49.42	5000	147.4	5.1	156.86	49.55	0	0	0	-2.3
	50.08	5360	152.6	1850	1770	49.81	5240	151.9	5.36	169.19	49.93	0	0	0	-2.3
	50.45	5600	154.1	1850	1780	50.2	5440	153.4	5.36	180.28	50.32	0	0	0	-2.3
	50.84	5800	154.1	1800	1790	50.58	5640	154.1	5.36	186.69	50.71	0	0	0	-1.5
	51.23	5960	155.6	1730	1760	50.96	5840	156.4	5.61	195.53	51.11	0	0	0	-1.5
	51.64	6200	149.6	1660	1700	51.35	6040	154.9	5.61	200.36	51.48	0	0	0	-1.5
	52.01	6360	145.1	1640	1660	51.76	6200	147.4	5.36	194.72	51.88	0	0	0	-0.8
	52.4	6480	142.9	1620	1640	52.15	6480	142.9	5.36	196.81	52.27	0	0	0	-0.8
	52.8	6600	140.6	1530	1620	52.52	6520	141.4	5.36	194.19	52.67	0	0	0	-0.8
	53.2	6760	134.6	1220	1540	52.93	6680	139.1	5.1	199.42	53.05	0	0	0	0
	53.58	6840	113.5	1170	1400	53.32	6800	124.8	4.34	174.89	53.44	0	0	0	0
	53.97	6800	23.3	280	1590	53.73	6880	110.5	3.57	160.89	53.85	0	0	0	0
Code:
	Group A:	'028				Group B:	'118				Group C:	'230
		Engine Speed	Engine Load	Coolant	Knock Sensor		Engine Speed	Intake Air	Boost Pressure	Boost Pressure		Pressure	Pressure	Pressure
	TIME	(G28)		Temperature (G62)	Test Result	TIME	(G28)	Temperature (G42)	Control (N75)	(actual)	TIME
Marker	STAMP	 /min	 %	°C		STAMP	 /min	°C	 %	 mbar	STAMP	 bar	 bar	 bar
	0.4	720	15.8	86	System OK	0.15	760	32	0	1010	0.27	50	49.66	0.34
	0.8	720	15.8	86	System OK	0.54	720	32	0	1010	0.67	50	49.98	0.01
	1.2	720	16.5	86	System OK	0.93	760	32	0	1010	1.07	50	50.48	-0.49
	1.57	760	15.8	86	System OK	1.32	720	32	0	1010	1.45	50	50.29	-0.29
	1.97	720	15.8	86	System OK	1.72	760	32	0	1010	1.84	50	49.49	0.5
	2.36	760	15.8	87	System OK	2.09	720	32	0	1010	2.23	50	50.03	-0.03
	2.74	720	15.8	87	System OK	2.47	760	32	0	1010	2.6	50	49.42	0.58
	3.12	760	15.8	87	System OK	2.87	720	32	0	1010	3	50	50.68	-0.68
	3.51	720	15.8	87	System OK	3.26	760	32	0	1010	3.38	50	49.51	0.49
	3.9	720	15.8	87	System OK	3.63	720	32	0	1010	3.77	50	50.71	-0.72
	4.3	720	15.8	87	System OK	4.03	760	32	0	1010	4.15	50	50.17	-0.17
	4.67	720	15.8	87	System OK	4.41	720	32	0	1010	4.54	50	49.27	0.73
	5.06	720	15.8	87	System OK	4.81	760	32	0	1010	4.93	50	50.03	-0.03
	5.45	1200	48.1	87	System OK	5.18	760	32	94.9	1000	5.32	51.07	49.1	1.97
	5.82	1000	34.6	87	System OK	5.57	1200	32	0	1010	5.69	51.34	50.47	0.87
	6.18	880	60.2	87	System OK	5.94	880	32	1.6	1010	6.05	50.51	49.59	0.92
	6.57	1040	53.4	87	System OK	6.32	1000	31	0	1020	6.44	50.59	52.1	-1.51
	6.96	1400	58.6	87	System OK	6.69	1120	31	0	1020	6.83	53.13	52.8	0.33
	7.35	1920	85	87	System OK	7.08	1520	30	94.9	1030	7.21	56.46	55.48	0.98
	7.72	2520	92.5	87	System OK	7.47	2080	30	94.9	1100	7.6	61.02	61.05	-0.04
	8.11	3320	115	87	System OK	7.86	2800	30	94.9	1290	7.99	66.4	65.58	0.82
	8.5	3200	15	87	System OK	8.24	3480	30	0	1540	8.38	67	67	0
	8.9	2880	22.6	87	System OK	8.63	3040	27	0	1240	8.75	66.99	66.99	0
	9.27	2240	32.3	87	System OK	9.02	2840	27	0	1150	9.14	61.75	63.26	-1.51
	9.66	1680	91.7	87	System OK	9.41	1800	27	94.9	1090	9.53	66.33	65.97	0.36
	10.05	1880	95.5	87	System OK	9.78	1800	27	94.9	1160	9.92	70.58	70.87	-0.29
	10.46	2080	103	87	System OK	10.17	1920	27	94.9	1250	10.3	74.95	74.44	0.5
	10.84	2240	113.5	87	System OK	10.58	2160	27	94.9	1350	10.72	79.63	79.81	-0.18
	11.23	2480	127.1	87	System OK	10.98	2360	27	89	1490	11.11	84.36	84.22	0.14
	11.62	2720	138.3	87	System OK	11.36	2560	27	36.5	1660	11.5	88.68	88.75	-0.07
	12.02	3000	145.1	87	System OK	11.75	2800	27	40	1760	11.87	92.84	93.74	-0.9
	12.39	3240	147.4	87	System OK	12.14	3080	26	37.3	1780	12.26	96.92	96.79	0.13
	12.78	3480	145.9	87	System OK	12.53	3360	26	37.3	1750	12.65	101.74	101.29	0.45
	13.17	3800	145.9	87	System OK	12.9	3600	25	37.6	1740	13.05	107.22	106.25	0.96
	13.56	4000	145.1	87	System OK	13.29	3840	25	38	1730	13.42	109.58	110.41	-0.84
	13.95	4240	145.9	87	System OK	13.68	4080	25	38.8	1730	13.81	109.94	109.21	0.73
	14.34	4440	149.6	87	System OK	14.09	4320	25	40.4	1740	14.21	109.99	109.26	0.73
	14.73	4720	150.4	87	System OK	14.46	4560	25	41.6	1760	14.6	109.99	111.12	-1.13
	15.12	4920	145.9	87	System OK	14.85	4800	25	42.4	1760	14.98	109.99	111.87	-1.88
	15.49	5120	148.9	87	System OK	15.24	5040	25	44.3	1760	15.37	109.99	111.55	-1.56
	15.88	5360	151.9	87	System OK	15.64	5240	25	45.9	1790	15.76	109.99	112.06	-2.07
	16.27	5600	154.1	87	System OK	16.01	5400	25	48.2	1810	16.15	109.99	108.1	1.89
	16.67	5760	154.1	87	System OK	16.4	5640	25	49.8	1810	16.52	109.99	110.72	-0.73
	17.04	6000	156.4	87	System OK	16.79	5840	25	50.6	1810	16.91	109.99	111.1	-1.11
	17.43	6160	148.9	87	System OK	17.18	6040	26	49.4	1770	17.3	109.99	110.49	-0.5
	17.82	6320	145.9	87	System OK	17.55	6160	27	48.6	1720	17.69	109.99	110.41	-0.42
	18.22	6440	143.6	87	System OK	17.94	6360	27	47.8	1690	18.07	109.99	109.15	0.84
	18.6	6600	139.1	87	System OK	18.35	6520	27	47.5	1670	18.47	109.99	109.92	0.07
	18.99	6760	137.6	87	System OK	18.74	6600	27	45.9	1640	18.86	109.99	113.96	-3.97
Code:
	Group A:	'015				Group B:	'016				Group C:	'020
		Misfire Counter	Misfire Counter	Misfire Counter	Misfire		Misfire Counter	 	 	Misfire		Timing Retardation	Timing Retardation	Timing Retardation	Timing Retardation
	TIME	Cylinder 1	Cylinder 2	Cylinder 3	Recognition	TIME	Cylinder 4			Recognition	TIME	Cylinder 1	Cylinder 2	Cylinder 3	Cylinder 4
Marker	STAMP					STAMP					STAMP	°KW	°KW	°KW	°KW
	0.12	0	0	0	Enabled	0.28	0	 	 	Enabled	0.03	0	0	0	0
	87.87	0	0	0	Disabled	87.6	0	 	 	Disabled	87.75	0	0	0	0
	88.26	0	0	0	Enabled	87.99	0	 	 	Enabled	88.12	0	0	0	0
	88.64	0	0	0	Enabled	88.38	0	 	 	Enabled	88.51	0	0	0	0
	89.02	0	0	0	Enabled	88.78	0	 	 	Enabled	88.9	0	0	0	0
	89.41	0	0	0	Enabled	89.15	0	 	 	Enabled	89.29	0	-0.8	0	-0.8
	89.81	0	0	0	Enabled	89.54	0	 	 	Enabled	89.66	0	-0.8	0	-0.8
	90.18	0	0	0	Enabled	89.93	0	 	 	Enabled	90.05	0	0	-3	-3
	90.57	0	0	0	Enabled	90.32	0	 	 	Enabled	90.44	0	0	0	0
	90.96	0	0	0	Enabled	90.69	0	 	 	Enabled	90.84	0	0	0	0
	91.31	0	0	0	Disabled	91.08	0	 	 	Enabled	91.2	0	0	0	0
	91.7	0	0	0	Disabled	91.44	0	 	 	Disabled	91.56	0	0	0	0
	92.08	0	0	0	Disabled	91.81	0	 	 	Disabled	91.96	0	0	0	0
	92.49	0	0	0	Enabled	92.2	0	 	 	Disabled	92.33	0	0	-3	-3
	92.86	0	0	0	Enabled	92.61	0	 	 	Enabled	92.73	0	0	-0.8	-0.8
	93.25	0	0	0	Enabled	93	0	 	 	Enabled	93.12	0	0	-3	0
	93.64	0	0	0	Enabled	93.37	0	 	 	Enabled	93.52	0	0	-3	0
	94.03	0	0	0	Enabled	93.76	0	 	 	Enabled	93.89	0	0	-2.3	0
	94.4	0	0	0	Enabled	94.15	0	 	 	Enabled	94.28	0	0	-1.5	-3
	94.79	0	0	0	Enabled	94.55	0	 	 	Enabled	94.67	0	0	-0.8	-3
	95.19	0	0	0	Enabled	94.92	0	 	 	Enabled	95.06	0	0	-0.8	-3
	95.59	0	0	0	Enabled	95.31	0	 	 	Enabled	95.43	0	0	-0.8	-3
	95.95	0	0	0	Enabled	95.7	0	 	 	Enabled	95.82	0	0	-0.8	-3
	96.35	0	0	0	Enabled	96.09	0	 	 	Enabled	96.21	0	0	-0.8	-3
	96.77	0	0	0	Enabled	96.49	0	 	 	Enabled	96.64	0	0	-0.8	-2.3
	97.15	0	0	0	Enabled	96.88	0	 	 	Enabled	97.01	0	0	0	-2.3
	97.52	0	0	0	Enabled	97.27	0	 	 	Enabled	97.4	0	0	0	-2.3
	97.91	0	0	0	Enabled	97.67	0	 	 	Enabled	97.79	0	0	0	-2.3
	98.31	0	0	0	Enabled	98.04	0	 	 	Enabled	98.18	0	0	0	-2.3
	98.7	0	0	0	Enabled	98.43	0	 	 	Enabled	98.56	0	0	0	-3.8
	99.08	0	0	0	Enabled	98.82	0	 	 	Enabled	98.95	0	0	0	-3.8
	99.47	0	0	0	Enabled	99.23	0	 	 	Enabled	99.35	0	0	0	-3.8
	99.87	0	0	0	Enabled	99.6	0	 	 	Enabled	99.74	0	0	0	-3
	100.27	0	0	0	Enabled	99.99	0	 	 	Enabled	100.12	0	0	0	-3
	100.67	0	0	0	Enabled	100.39	0	 	 	Enabled	100.53	0	0	0	-3
	101.07	0	0	0	Disabled	100.82	0	 	 	Disabled	100.94	0	0	0	0
	101.45	0	0	0	Disabled	101.19	0	 	 	Disabled	101.33	0	0	0	0
	101.85	0	0	0	Disabled	101.58	0	 	 	Disabled	101.71	0	0	0	0
	102.22	0	0	0	Disabled	101.97	0	 	 	Disabled	102.09	0	0	0	0
	102.62	0	0	0	Disabled	102.36	0	 	 	Disabled	102.48	0	0	0	0
	103.02	0	0	0	Disabled	102.75	0	 	 	Disabled	102.89	0	0	0	0
	103.41	0	0	0	Disabled	103.14	0	 	 	Disabled	103.26	0	0	0	0
	103.79	0	0	0	Disabled	103.53	0	 	 	Disabled	103.65	0	0	0	0
	104.18	0	0	0	Disabled	103.92	0	 	 	Disabled	104.05	0	0	0	0
	104.58	0	0	0	Disabled	104.31	0	 	 	Disabled	104.45	0	0	0	0
	104.98	0	0	0	Disabled	104.71	0	 	 	Disabled	104.84	0	0	0	0
	105.36	0	0	0	Disabled	105.1	0	 	 	Disabled	105.23	0	0	0	0
	105.74	0	0	0	Disabled	105.5	0	 	 	Disabled	105.62	0	0	0	0
	106.14	0	0	0	Disabled	105.87	0	 	 	Disabled	106.01	0	0	0	0
	106.53	0	0	0	Disabled	106.26	0	 	 	Disabled	106.38	0	0	0	0
	106.9	0	0	0	Disabled	106.65	0	 	 	Disabled	106.77	0	0	0	0
	107.3	0	0	0	Disabled	107.04	0	 	 	Disabled	107.16	0	0	0	0
	107.69	0	0	0	Disabled	107.41	0	 	 	Disabled	107.57	0	0	0	0
robdf2
Yellow is the best
Feb 21, 2006
3,605
location , location
hi mate i only run v power , thats what i dont get , SEAT say my timing pull is normal wtf? :censored:
Dec 2, 2008
571
Nottingham
Problem Identified
Went to visit Ben (Master VAG Tech) and Carl at REVO yesterday for investigation work to establish why my car was running badly and not boosting to say the least and why Monster couldn't set the REVo setting correctly without it running in det.
Firstly, great service, Ben is a fountain of knowldge and defo lives up to his title!
In summary problem identified as fried coil pack. Ben replaced for me, road tested and set REVO up correctly (B7, T5, F9). Now pulls much stronger and runs well.
However, bigger problems ahead. The coil pack fried 'cause oil has been leaking into the spark plugs holes.
Ben suspects this is from a leaking gasket on the cam shaft bearing carrier and will need sorting otherwise it will start to run like a bag of sand again and fry another set.
Ben was happy to do the work for me but suggested to save me cash since the car is under warranty I persue with SEAT. He did say I may have to be forceful with them to get the work done as they will say 'no warranty claim as modded'
However, Ben believes they can not refuse to do the work as the fault is not as a direct result of the modifications done.
I'll update on how I get on
robdf2
Yellow is the best
Feb 21, 2006
3,605
location , location
hi Dave yep agree with you Ben is a top bloke gave me loads of time and plenty of knowledge ,
dont know why seat make it a secret society? i learnt more from Ben in an hour bout my car than 2 years of speaking to seat so called experts.
looks good that you getting things sorted.
would be good to see any pics of this as you know i have similar problems maybe this is a common fault?
not sure how oil gets into the spark plug holes?
i am on my 3rd set of plugs in around 15,000 miles , the threads of my plugs are covered in oil and the general state of them is black evn the latest set which has done about 5k.
its had the uprated ngk plugs installed they lasted about 8k , each time just had new plugs fitted so obviously more to mine than they want to let on about !
was your actual spark plug hole filled with oil? or was it just a witnes like mine around threads , is your using oil? mines burnt half my dipstick in 5,000 miles
Poverty
Good luck with the stealers!
robdf2
Yellow is the best
Feb 21, 2006
3,605
location , location
yup 2nd that , might be a good idea at least to take the itg off and put standard cover back on , from my experience nothing will happen with out a fault code and they wont take a 3rd parties word for anything , unless you can prove things to them , remember my door problem? that took 5 months before they accepted liabiity and they could see the damage missing parts with out removing anything , dont get me wrong im on ur side dave totally but i know what a bunch of fobbing off robbing gits they are
K1Shane
336bhp 319 lb/ft
Apr 17, 2010
730
Northfleet
I'll 2nd that, useless, moneygrabbing, bring a bad name to a brilliant brand :censored::censored:
Poverty
yep no fault code, no action.
Even pages and pages of vag com fault codes taken over a period of 12 months wont kick stealers into action
Dec 2, 2008
571
Nottingham
I don't think they were black (or white), I'll need to check with Ben but if they are the same as when I replaced my plugs just oil residue on some of the plugs.
Ben also advised me that use TFSI owners shouldn't get sucked in by the sales patter on the NGK plugs. Basically becuase of the way the engine is design buying so called 'colder' plugs makes no difference. These plugs only really benefit older engines. Ben recommends next time going with OEM plugs rather than spending extra on the NGK Iridium plugs.
I've started with an e-mail to SEAT to test the water.
Irrespective of logs and evidence surely just spending 5 minutes taking the plugs out and seeing the oil deposits would be enough to convince them of a leak.
I'll happily take pictures of my old coil pack but probably won't be clear enough on pictures. Just deposits on the end and the outer cases slightly tarnished
Dean T
Quite an interesting read there. Sounds like the revo master tech certainly knows his stuff!
Best of luck with your dealer and keep us posted fella.
Al
7,331
9
This is the 5th one now I know of. Ones I know of already;
1 Ed 30
2 Cupra
1 S3 (needed new engine)
Poverty
1 Ed 30
2 Cupra
possible weakness in the engine and not mod related seeing as iirc invisble hasnt been stage 1 for that long, and 300hp isnt exactly pushing the envelope either
