Tyre Pressure Monitoring system
oomyactualoomfy
Hi, can anybody help me???? Ive fitted a set of non manufacturers 18's on my 2006 leon fr.The tyre pressure monitoring light is now on. Can anybody tell me if this system can be turned off to extinguish the warning light on the dash.
cheers
iain
I have fitted a set of 18's on my 2006 leon fr.The light for the tyre monitoring system has now came on.Can i turn this off or can a dealer turn it off? HELP............
chrisboyle999
MFD3 for sale, inbox me.
Nov 28, 2006
1,838
Geordieland
ign on, press button until you hear a 'bong'.
light should be out.
if not it may need a trip to the stealers.
tyre/wheel type doesnt matter a hapeth.
Dec 15, 2007
1,143
South East London
Did you get manual with your car?
A REAL man never reads a Manual..... I have never read a manual and have a cupboard full of perfectly good gadgets that obviously are defective to prove it!
My manual did however once fall open on the page about the tyre sensor and I held the button down like you said and not a peep from mine when i replaced my alloys....
OLDOILER
1,292
Wiltshire, UK
cheers
iain
Make sure tyre pressures are correct them press the reset button on the centre console for at least 10sec and the light should go out - unless you have a broken sensor /wire on the hub - then it is tripto the stealers. ..................................
clinko
14
Have the same problem myself. Ive been told the actual button needs replaced, and the button is on back order so dont know when i'll get it fixed
chrisboyle999
Nov 28, 2006
1,838
Geordieland
why cant they burgle one from a showroom/demonstrator car for you and score a cheap brownie point into the process?
suggest it, and see what they say. would take, ooh, quarter of an hour, tops.
clinko
14
Thats something i never would of thought off! While talking on the phone i found out that this button has already been recently replaced on my car(I only have it 2 weeks) I smell a rat!
TheLunchCrasher
You can always turn it off via VAGCOM, do a search in google and am sure something will come up. I turned off the annoying seatbelt warning light so I can now put stuff on the passenger seat, that was using VAGCOM
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
still got the sensors in the wheels after fitting ?
used to get it a lot at renault - fitters ripped out the valve and sensors with it and put in normal ones before refitting
mind you they were as reliable as a train timetable had cars forever coming in for resets
Tam
Santa in disguise :)
Feb 10, 2005
1,777
Near Reevo :)
Doesn't have sensors in the wheels.
It works by using the ABS sensor monitoring rotational speed, then compares it to all the other wheels, if one is out .. then it calls puncher.
Works great, but won't pick up slow loss in all 4 tyres (natural loss over time) - which a sensor inside the wheel would ...
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
quite a fine line of measurement then i guess
i wonder how they get around the confusion for ABS and traction/stability control then
mmm interesting
Jul 10, 2007
1,267
Leeds
I can vouch for it working great. Detected my puncture straight away, just needed to make sure I reset the system once the new tyre was fitted.
ADzABOUT
55
NEAR NORWICH
HI ALL JUST HAD 2 BACK TYRES FITTED BUT CANNOT GET THE LIGHT OFF THE DASH!
HELD BUTTON DOWN NEAR HAND BREAK BUT NO LUCK.:cry:
WHEN I BOUGHT THE CAR IN SEPT 09 THE GARAGE PUT 2 NEW TYRES ON THE FRONT AND ON MY WAY HOME THE LIGHT APPEARED, WHEN I STOPPED I READ MANUAL...PRESSED BUTTON.....LIGHT WENT OFF. GOT A FLAT BACK TYRE 2 WEEKS AGO AND LIGHT CAME ON, SO SYSTEM OBVIOUSLY WORKING, BUT NOT NOW. ANY HELP WILL BE APPRECIATED. ADAM
Nath.
The Gentlemans Express
Jan 1, 2006
8,620
16
EASTLEIGH, HAMPSHIRE
Replace the button ? Also your caps lock button seems to be defective too. :rolleyes:
ADzABOUT
55
NEAR NORWICH
lol bout caps lock! thanks for reply if i got a button, do you know if its much of a job to do myself or is it best to take to a garage?.............................also i read a bit on another thread and someone said about VAGCOM do you know much about this? thanks again.
ADzABOUT
55
NEAR NORWICH
Oh yeah meant to say bloody seat want £50 + vat just to plug it in to computer! Can't beat this website!
I got this done months ago by the way just wanted to update the thread.
