there is a way to disable the cornering lights without the use of laptop or any kind of program.
i did it on mine.
behind the light control switch you just pull out pin 11
or as i did i cut it and installed a switch on pin 11 cable, and whenever i want cornering on i put the switch to on position and when i want cornering off i put it at off position.
the pin 11 cable is the cable that goes to the cornering control unit and tell it if the lights are on,
so if we cut it, the cornering control unit thinks that the main lights are off so it doesn't turn on cornering.
it is like the command pin in a relay.
i figure it out one day by messing with my cables
hope I helped.
Some very good info there! Thanks for sharing
