fuzzy
78
Bournemouth
Have a 52 plate lc
Heard about 20v engines with chargers on, Im after more power, would this be a good route or would it be a waste of time
A supercharger is powered by a belt, or chain, connected to the engine's crankshaft.
in order to use a supercharger, sometimes as much as a third of the total crankshaft power of the engine has to be used in order to driver the supercharger
though you'll probably gain up to 5-10 times the amount of power used.
still, when your talking FWD and power limitations, just going for a turbo replacement seems a better and cheaper option
indeed, but if it was turbo AND supercharged.... :) no lag and MASSES of power.
Although that is possible to do with some cars, i dont know if its possible for a LC or LCR, and im not sure the cost ares worth the results myself.
if i had limitless money its probably something i would try but since im fairly poor i'll stick with the stock k04 turbo for now. :)
if you want to be different with the SC route, go to **Storm Developments Clicky***
they Supercharged the 1.8T engine and produced quite a bit of power and the kit is still in development, most interesting of course that there is no lag with an SC
I am not saying its the best option, nor the worst, but its an idea and certianly on this forum would be a one off, as in someone swapping the Turbo for an SC
