Turbo Stops Working
JONNYVT
219
LEICESTER
I have a 2001 Cupra (1.8t). Sometimes the turbo stops working, no boost at all. If i turn off the ignition & RESTART, it works again. the car has done 80k with no trouble (other than coils). My dealer says its prob a wastegate fault telling the ecu to shut down the turbo, restarting resets everything and lets it work again.
The dealer says they have to take off the turbo & see if they can rebuild it, they will charge me 2 hours for diagnostics, £350 plus vat to take a look THEN £1000 plus fitting if it needs a new turbo. I've also been told that the wastegate is integral & cant be replaced on its own (by one of the SEAT mechanics when i described the problem)..
Does anyone have any experience of this problem, is there an easier & cheaper way to fix it? Can the turbo BE rebuilt/fixed or should i just plump for a new one?
Please help.
JonnyVT
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
have a nosey in the traders/tuning sections on here, theres jbs, badger5, westec, awesome etc someones bound to be able to sort you out.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
Please help.
JonnyVT
stops working like what....
any fault codes logged?
turbo in itself wont just stop working.. not on-off like you describe.
control of wastegate actuator (N75) and DV or its control (N249) can do this tho.
I would start at the easier (cheaper) end of diagnosis first before jumping in with £1000 new turbo. - ya typical dealer type anwqer being to throw parts at it until it goes away. (ok if warranty picks up the tab, bad news if you have to)
Tavia4x4
Merc Minibus
Mar 18, 2002
277
Lancashire
Sounds very much like a 17705... you have a boost leak somewhere, N75 \ N249 or one of the pipes... there is a pipe underneath that can easily get snagged, in fact they redesigned the clip on the pipe later.
My octy is an 01, and I had exactly that. Get some codes, then go from there.
Saul
<b>SCN Admin</b>
May 21, 2001
4,194
you will need vag-com or similar with the appropriate cable to read your fault codes
www.ross-tech.com or look on ebay
does sound like a limp mode fault
Jonzy
Ive got a similar problem, sometimes the car boosts hard other times its like the turbo is not exsistent. Can hear the turbo spooling but just doesnt feel 'right'.
JONNY BRONCO
Bloody stealers! can't believe they are trying to charge you that amount of money. what a rip off. there are plenty of options out there,leave main dealers as last resorts.
Ruddmeister
Everything in Moderation
Jun 23, 2003
8,218
Weston-super-Mare
en.wikipedia.org
Sounds like your car is going into limp mode maybe.....again a dealer or VAG specialist should be able to check and see fault codes
JONNY BRONCO said:
Bloody stealers! can't believe they are trying to charge you that amount of money. what a rip off. there are plenty of options out there,leave main dealers as last resorts. .
Does it only happen on cold mornings when you start the car?
Jonzy
Just been out in the car and it was fine, gave it a 3 figure run down the *ahem* private road , was fine, stopped to get some cash and then it wouldnt pull properly when it restarted.
I have noticed that if it happens on the move that thers a small jolt, usually in 2nd, around 4750-5000rpm.
Really annoying now!
