Hi guy!; Can you help me!!
I have this problem!
Sometimes (one of day) when I push on the accelerator from 2500 rpm in every gear 1 or 2 or 3, the turbo increases only up to 1.2 bar without peak until 7000rpm.. then when i try again the car is fine and runs stable at 1.35 to the limiter and peak of 1.75.
What is the reason??
with vag com I haven't found faults!!!
I have installed Forge divert valve with yellow springs, ngk iridium Ix, s3 IC , miltek complete exhaust 3",remapped,kmd hpfp,carbonio intake.
THANKSSSSSS
THANKSSSSSS
