Hi all,
I am new to this forum so I hope I've added this thread in the right place. My wifes 2007 Altea XL 2.0 TDI recently went into limp mode whilst motorway driving. I can not diagnose what the cause is but I have checked several things and have ran out of ideas.
The car has now done 105,000 miles and probably done 3000 since the problem reared its ugly head. It still has good power and torque upto limp.
I have an ELM adaptor and using the Torque app I can see it enters limp mode with P0234 Turbo overboost. It will reset with the reset command or on power down. At high revs the turbo can be heard whining but I'm quite sure the turbo is still good. If you hold the high revs/power for 5 seconds or so limp is triggered.
So far I have tested.
With a vacuum pump/gauge I can operate the actuator. The turbo VGT actuator moves with the correct pressure, its a garret and starts to move at 5 inHg and stops at 18inHg. It holds pressure (including the hose) for atleast 30 mins.
I removed the exhaust pipe and did the Mr Muscle trick in the turbines, I believe the vanes are free.
Using Torque App I can see the boost pressure reaching 1.6 bar before entering limp so I deduce the boost sensor is good.
The MAF sensor is working too. I can see this change with speed etc up to 100g/sec.
The EGR valve just before the inlet manifold opens and closes with my vacuum pump. ( I do not know the correct pressures but it opened at about 5 inHG and stopped at 15 inHg.
The butterfly valve below this in the same housing (throttle valve perhaps?) operates by hand atleast and the valve is clean. I did not test the electrics on this valve.
The N75 manifold/control gadget appears to be working. I say this as I fixed my vacuum gauge to the VGT actuator line whilst driving and I can see it goes to 18-20 inHg at idle and varies with driving conditions. It flicks to zero bar when lifting foot off the gas and it does reduce in vacuum as the engine gains rpm.
So now I've ran out of ideas. It is possible that the N75 can still appear to work, i.e. its's not totally dead, but does not work correctly? I do not know what other inputs are part of the VGT actuator control system.
I am reluctant to take it to a garage as I've read so many stories of garages just saying you need a new turbo and I want to avoid spending more than necessary getting it fixed.
Any ideas or advice would be greatly appreciated.
