Hi guys,
After some know how, here's the story, 3 weeks ago I did a lot of work on my car, 2 of the bits I changed which could have caused this are the DV (Forge 008p yellow spring) and a Forge TIP, now it doesn't matter if it's been programmed with stage 1 or original (I have the box to change it whenever I like) but in the last week, whenever I have turbo boost (all gears) and I let my foot off the accelerator I get a light fluttering/chattering for about a second from the airbox area of the car. Now bearing in mind it was fine for 2 weeks not a peep as well I'm a bit baffled.
The turbo is a KO4 on a BAM engine.
I have taken the DV apart, checked it, everything is fine. I was under the impression a stage 1 using a yellow spring was a good idea but I could switch to green if people think it would be better, maybe put all 3 shims in as well?
I haven't run an n249 bypass as yet, considering it due to this though if people think it might help? The only other thing I could think of is it's the waste gate but I haven't got a friend with me to check it as I'm away on business.
How long realistically could I drive with it like this before risking serious damage to the turbo? If it would damage it at all?
Thanks lads/ladys.
Thanks lads/ladys.
