Trying to reduce Cfs LCR - APR Stage1
ChrisGTL
'Awesome' LCR225
Nov 17, 2007
2,459
Huddersfield
I'm trying to work out why I have so much CFs on my mapped LCR. I'm running an APR stage 1 with the following;
SAMCO TIP
007P
Jetex Cone /w 3" CAI
New OEM plugs
Toyo FMIC
Did some more logs today as the outside temp was low. 5.5C on the dash
0 Timing
Code:
'003				Group B:	'020
RPM	Mass Flow	Load	Ign. Timing		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
2680	70.53	100	23.3	73.38	0.8	0.8	3.8	0.8
3000	116.67	100	3	74.19	0	0	3	0.8
3400	131.53	100	3	74.99	0	3	2.3	0.8
3880	146.11	99.6	8.3	75.79	0	3	2.3	0.8
4360	160.42	100	10.5	76.71	0	2.3	1.5	0.8
4800	175.17	100	14.3	77.51	0	2.3	0.8	0
5200	186.47	100	11.3	78.32	3	1.5	0	0
5560	190.61	100	11.3	79.12	3	3.8	0	0
5880	193.39	100	13.5	79.92	3	3.8	3	0
+1.5 Timing
Code:
'003				Group B:	'020
2840	27.14	14.9	41.3	83.47	0	0	0	0
2960	74.67	98.8	27	84.39	0	0	0.8	0
3280	142.31	100	1.5	85.19	3	6	0.8	3
3840	146.83	100	8.3	86.1	3	6	0.8	3
4360	159.47	100	13.5	87.01	2.3	5.3	0.8	2.3
4840	175.17	100	15.8	87.91	1.5	3.8	0.8	1.5
5240	185.22	100	16.5	88.71	3.8	3	0	0
5640	191.53	100	12	89.52	3.8	5.3	3	0
5960	194.33	99.6	12	90.42	3.8	5.3	3	3
6240	199.39	99.6	12.8	91.23	3	4.5	3	3
6480	197.14	98.8	18	92.13	3	4.5	2.3	1.5
6520	3.56	7.5	10.5	92.94	2.3	6.8	5.3	1.5
-0.75 Timing
Code:
'003				Group B:	'020
2880	26.03	13.7	38.3	70.92	0	0	0	0
2920	27.31	14.9	39.8	71.72	0	0	0	0
2960	38.86	19.6	36.8	72.53	0	0	0	0
3040	40.06	19.2	37.5	73.43	0	5.3	0	0
3320	133.58	100	5.3	74.23	0	5.3	0	0
3760	143.64	100	9	75.04	0	5.3	0	0
4200	157.61	100	11.3	75.94	0	3.8	0	0
4720	167.11	100	13.5	76.76	0	2.3	0	0
5160	182.44	100	12	77.65	0	4.5	0	0
5560	188.78	100	13.5	78.66	0	4.5	0	0
5920	193.39	100	12.8	79.46	0	3.8	0	0
6160	194.94	99.6	9.8	80.39	0	3.8	0	0
6320	0	4.7	34.5	81.28	0	0	0	0
ChrisGTL
'Awesome' LCR225
Nov 17, 2007
2,459
Huddersfield
Intake temps were typically;
Code:
'003				Group B:	'118
RPM	Mass Flow	Load	Ign. Timing		RPM	Temperature	Load	Absolute Pres.
2920	30	14.5	36.8	20.53	2880	17	0	1260
2960	29.64	14.9	33.8	21.42	2920	17	0	1200
2960	29.33	14.5	39.8	22.33	2960	18	0	1150
2960	29.86	14.9	39.8	23.13	2960	18	0	1130
3000	34.81	16.9	37.5	23.95	2960	18	0	1130
3000	34.97	16.9	38.3	24.84	3000	18	0	1180
3040	49.06	29	37.5	25.66	3040	18	0	1190
3200	120.94	100	10.5	26.56	3120	17	95.3	1440
3440	130.78	100	3	27.36	3320	15	79.6	2420
3800	141.36	100	9.8	28.17	3640	12	79.6	2400
4080	152.19	100	11.3	29.07	3960	12	79.2	2320
4360	155.64	100	12.8	29.88	4200	12	79.2	2300
4640	160.97	99.6	10.5	30.78	4520	12	79.2	2210
4840	167.47	100	10.5	31.58	4720	12	80	2220
5080	180.25	100	11.3	32.49	4960	13	80.4	2170
5280	189.97	100	11.3	33.29	5160	14	85.1	2180
5480	190.31	100	11.3	34.22	5400	15	87.5	2160
5640	191.33	98.4	10.5	35.11	5600	16	89.4	2140
5840	194.61	100	6.8	36.11	5760	17	87.8	2130
6000	194.61	100	11.3	37.02	5920	18	90.6	2040
6160	195.72	100	12	37.82	6040	18	84.7	2090
6240	194.17	99.2	9.8	38.63	6160	19	83.9	2040
Avant4me
359
Bristol
They are not massively high on 0 timing, but still more than i ever had. Weird how its just one cylinder. I used to get very high CF on my LC after fitting my turbo back exhaust, but it was across the board. After a custom map i got to down to below 2 even at spool up point which is the worst point. Have you tried swapping a spark plug and coil to another cylinder to see if the CF moves?
ChrisGTL
'Awesome' LCR225
Nov 17, 2007
2,459
Huddersfield
No I didnt think of it in that way. I suppose it is possible to get a weak spark plug, does those logs mean that the CF's are in banks 1,2,3,4? Bank 1 been the very most left bank as you look at the engine from front of car?
I've had REVO flashed to my car now and the CF's are much lower, I was able to put 1.5degrees of timing on without CF's been anything to worry about.
I've got a new set of NGK's which are one grade cooler, not sure if a stage 1 would run good on these though?
