TRAX @ Silver stone - are you going??
t32er
yea to the temp sensor but i dont know if mine is naffed or not...
N75 is the valve that basicly controlls the boost, the cupra and the R have n75 F valves, the J came from the audi S2 and the H is from the RS4, im running the H on the R, i had the J on my cupra, J on the cupra will give it a little more boost, about 2psi and hold it for a little longer BUT some time will kick it in to a soft limp mode...
i put a J on the R, it boosted to about 24psi, good times but dropped and held only 10-12psi, bad times
the H im runningboosts to about where it did on the oem F but it wont drop a singel psi till i change gear, good times BUT it is only boosting to around 20psi on a stage 1 map??? my cupra boosted more...
Seat Gooner
A.K.A Mark
Feb 28, 2009
1,952
Wisbech
im going to change mine dont think theres anything wrong with it just curious so by all means tez i can give you my old one if it helps then sorted if it dont bin it lol
t32er
i would try another F or give a J a go, ebay.. about 45 quid used or 60-90 new, on the other hand i would do what i do and call a breakers, i will get you the number for the place i use, used N75 for less than 25 quid posted.... happy days
t32er
So tez how for your N75????? :)
give it ago first mate see if it works... can sort some thing out sunday if it does
just read ya txt mark, i just thought, id said i had the gauge, i couldnt let you have it it with out it, i went back to where i got it, then found out it didnt come with one any way lol... it was only about 12 quid i think i got an adapter for it too as i didnt know what thread you would need, i had a few other bits to get too
t32er
what ever mate....up to you on that one....
like i said, i was going to sort the gauge out for ya, only thing needed no would be wires....
