Tracking - not steering straight
Dafg
Maybe someone can help - bought a 130 TDi Sport last week (2nd hand), v.happy with it (although may stiffen suspension a bit) but have noticed that when the steering wheel i horizontal it drifts to the left. Is this cause to check out the tracking or something else? Anyone else had similar problem?
Cheers.:confused:
Dafg
No, tread etc is fine and defo not caused by the road. Will take it to the dealer to have a look...
Nath.
The Gentlemans Express
Jan 1, 2006
8,620
16
EASTLEIGH, HAMPSHIRE
get it to quik fit or similar to check the tracking
they only charge to adjust but checking is free at quik fit!;)
also they fix punctures for free if you leave the wheel with them to do at their leisure;)
Nath.
Jan 1, 2006
8,620
16
I've never had any probs apart from balancing not 100% spot on but they corrected it for free the next day
have you had a bad time with them?
DEAN0
Old Git
Feb 1, 2006
5,356
347
Preston - UK
Dafg - Anyone else had similar problem?
Mine is doing the same - had the tracking checked by two different places who both siad it was correct.
Finally had a full geometry check done on the car and found out that the front camber is not equal.
Front drivers side is - 0º 39' as it should be according to the book.
Front passenger side is - 1º 05'
There is no official way to correct this error in camber.:wtf:
The only suggestion was to take it to a local rally car builder and have him elongate the ball joint holes in the wishbone to move the wheel in slightly to correct the camber.
muddyboots
Still hanging around
Oct 16, 2002
5,739
There is some movement possible the top suspension mount bolt holes.
And I believe it's possible to shift the subframe slightly, with the same effect.
I'd echo m0rk's view of Quick-fit type places; went to have mine done once, got told they'd sent the equipment away as it was found to be several degrees out...and that was after they'd done quite a few cars with it.
The kit often gets chucked about and the people using it don't usually take much care setting it up, or understand much about suspension either...
muddyboots
Oct 16, 2002
5,739
Dafg -> Whereabouts in the country are you ? Someone might know of a reputable specialist in your neck of the woods.
RichieRich
Mk4 Golf GT TDi
Sep 17, 2005
2,367
Oxfordshire :)
www.bebo.com
i have the same kind of problem but it seems like its not possitive going around left hand corners than right, i thought it was to do with the steering pump and it was easyier to turn that way aswell, the nearest seat garage is 30 miles away and there crud lol does any1 else feel like that? im seriously thinkin about asking them to have alook.
