MichaelMr
Hi guys,
Trying to remove the Track rod ends on my mk3 cupra.
They are inverted, and proving really difficult to remove.
After using anti-seize and heat they still wouldnt turn, then the nut and bolt sheared off rather than turning, when applying force so now its still attached but the rod end is broken off inside the mount.
I've tried drilling them out but that hasnt worked.
My Question is should i use - or will i be able to use a Ball Joint Splitter? If so which one is best? Fork or Scissor.
Hoping i can still pry this out but theres no bolt and thread, so will i be able to get any leverage?
Thanks,
Michael
Thanks,
Michael
