Tow strap
Jul 30, 2010
571
Argyll, Scotland
Got a tsw tow strap nd wondering how best to fit. Have custom made a bolt for the original tow point but not sure how it will look. Any other suggestions on where to fit it
butch20vt
right it wont work if you try the original tow eye hole it will just look gash so what you need to do is take the front bumper of and slice a nice straight line going across just up from the original hole and the strap will fit spot on.
ndbrgr
THFC
Jul 21, 2008
1,023
Kent
I've got a proper bolt in one, sticks out too far if you want to run it as a fashion accessory though.
gazcuprablk
my 300+ death box :)
Mar 31, 2006
858
south wales
heres mine i cut a notch in my bumper for it to stick out its bolted to the original tow eye but with nut and bolt car be towed with but i wouldnt unless its on a rope you dont want a towing bar going through your rad lol
Nov 2, 2004
9,335
South Wales
Fix it behind the OE tow eye plate then drop it through the opening just below the fog light..thats how mine is and you can tow with it also ;)
How does that work? Doesnt it pull the bumper up as the tow eye plate is above the slot?
Brilliant if it has no issues, ill be ordering one tonight.
cozzy1990
Did you buy yours with the bolt attached already? if so where can it be bought ha.
ndbrgr
THFC
Jul 21, 2008
1,023
Kent
Quite a bit. They custom fab it though, so if I was to do it again I would just ask them to make it as short as possible.
