Torgue settings for wishbone driveshaft cv joints wheels
Pyro
I need some torque settings from you people :D
Ones the settings for
•the passenger CV/driveshaft bolts, the six bolts that bolt it to the gear box
•the hub nut
•the ARB to wishbone bolt
•the wishbone to subframe bolts
•and tge wheel nuts :)
Im not sure that the ones I have are correct :(
any help would be great and much luv in advance
csd_19
2,280
28
Angus / Edinburgh
Alright Sam :)
Torque figures are as follows:
Inner CV to gearbox flange bolts - *SHOULD* be M10 bolts and hence 80Nm.
Hub nut - 300Nm initially (with car off the ground) then slacken by 1 turn. Lower the car until partially on its wheels and retighten to 50Nm + 30 degrees. *NOTE* the hub nut should be replaced.
ARB link to wishbone bolt AND link to ARB - both 30Nm. Wasn't sure which bolt you were after so checked both.
Wishbone to Subframe-
Front: 70Nm + 90 degrees, bolt should be replaced as it is torque to yield.
Rear: 70Nm + 90 degrees, again bolt should be replaced as it is torque to yield.
Wheelnuts- 120Nm
All figures stated above are taken from Elsawin - I take NO RESPONSIBILITY for any damage or injuries you may incur using them.
Good luck with whatever rebuild repairs you are up to!
Pyro
cheers mate really helpfull ive gone and got nearly all the parts i need just need this one but cant find a part number :( its this one anyone got an clue??????
Pyro
:shrug: dunno lol but got the number so bonus :D all I could think to call it was engaging cap!! Lol gunna have a chat with Dave ;) cheers buddy
Pyro
All sorted car seems to be fine so no more damage done :D thanks for all the help and a massive thanks to Dave for getting me the parts I needed in record time :) your a legend Dave :clap:
