Timing chain on 1.2 engine Write to Watchdog!
Lordy
Have written to Watchdog regarding the problem a lot of us have had with the timing chain slipping on the 1.2 Ibiza engine during a service. This appears to be quite a common occurance and I urge everyone to write to Watchdog with their stories and how much it has cost you. Hopefully after getting nowhere with SEAT customer services, this approach might work!!
The address is:
BBC Watchdog, 201 Wood Lane, London W12 7TS
Phone No: 020 8535 1000
E-Mail: [email protected]
Good Luck,
Lordy
Lordy
This morning got a standard letter saying that my details are being stored on the database at Watchdog. If everyone writes to them they will probably start to investigate!!
Nath.
The Gentlemans Express
Jan 1, 2006
8,620
16
EASTLEIGH, HAMPSHIRE
can you give more detail why it slips during servicing?
I can't work that out either, can't see what servicing has to do with it apart from LACK of servicing
Yes it is a common problem and IMO people should be getting the 1.2 cars in for a check even if it costs a few quid just for prevention rather than cure
Then get it in wrighting that they reckon it's good to go
Guinness
Finally got the BMW
Nov 29, 2006
4,422
Newcastle
From what Im told its down the tensioners and the vecoity of the oil dropping. So baisicly get the tensioners changed all the time and change the oil all the time as well and your fine. There is also a kit to fix it, but as said seat do a good will gesture for this as well so dont really think watchdog are going to help you much lmao
rocky2008
Buy Cheap Buy Twice!
Nov 16, 2008
1,029
North-east
seat brought out some longer chain guards which were supposed to give it the chain more support...in my opinion its just wear and tear.
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
Also a big factor is oil capacity.
The 1.2 holds around 3 litres of oil, most of the time when a chain slips its been because the oil level has been allowed to get to low, the chain tensioner goes slack as its fed by oil pressure and the chain slips.
As the engines are allowed to use a litre of oil per 600 miles before its considered excessive you can see not keeping an eye on the level regularly can be the issue.
stezo2k
Anjuna Monkey
Mar 15, 2008
2,804
Dudley
i'm on 80,000 miles and i've had no issues what so ever regarding the timing chain *touch wood* i'm sure its not as common as people think
