timing belt change tools
MR T
129
7
BOONDOCKS
i have a 2004 ibiza 1.9 130 sport and it is due the cambelt change soon i work at a vauxhall dealer so will be getting it done there by one of the old techs knows what he is doing. anyway are there any special tools needed for replacing the belt have tried the search function but can't find anything about tools cheers
PhilOfCas
478
The capital of Yorkshire
search on here http://forums.tdiclub.com/, loads of warnings about not having the correct tools
Viking
Insurance co's are crap.
May 19, 2007
2,317
Near Richmond, North Yorks
Full set of essential VAG timing belt tools is available here. You can buy just the diesel kit I think, but I haven't looked for it.
A mate works for VW, and the pd engine timing belt change is one job that they're required to have checked by another technician before the engine is turned over. He's never cocked on up, but he still gets it checked when he does them. Destroys the engine if you don't have things correct, or at the very least bends a few valves and makes it a bad day for the technician involved.
MR T
129
7
BOONDOCKS
sounds like a b@st@rd of a job can't seem to find enough information on it just bits here and there on the odd vw forum. may have to find a specialist which is frustrating when you work in a garage yourself
Feb 1, 2007
1,602
Nottingham
Its an easy job with the correct tools the hardest part being getting the belt onto the cam pulley, it will be really tight even before you tension the belt!
Glynn
muddyboots
Still hanging around
Oct 16, 2002
5,739
I bought a timing tool kit when I did my Passats timing belt (same engine).
Didn't cost much, think it was from Laser tools ?
Have to dig around and see if I can find which set it was.
From memory you need:
1) A locking pin to poke through the cam pulley
2) A prop to take the tension off the tensioner
3) A device that locks the crank pulley - it's got teeth that engage with the crank pulley, then locks into the block.
