Hi i just need a quick reminder as i forgotten but how do you align the throttle body? Is it turn your ignition to full and leave it 20 minutes?
i have vagcom il have to do some serious reading cos ive never used it lol
Turn the key on but do not start the car.
[Select]
[01 - Engine]
[Measuring Blocks - 08]
Group 060
[Go!]
[Switch to basic settings]
Once you do this you will see the top right display say ADP RUN. The TB adaptation is being done as soon as you switch to basic settings. You will see the values change and hear the TB cycle for the first few seconds then it will stop. Leave it in Basic Settings for about 30 seconds.
[Switch to Meas. Blocks] button and you're all set.
Be sure not to touch the accelerator and make sure the engine is NOT running when you do this!
From Ross Tech for DBW 1.8T
cool thanks, does anyone know if this effects any revo settings?
Make sure the car is stonen cold
Open bonnet.
Turn ignition on so dash lights are on.
Leave for a minute ot two, you can hear the TB screaming. lol. Will click when its done.
Close bonnet.
Take keys out.
Start.
Sorry to drag this up .
If you dont TBA after disconnecting battery, what can it cause ?
thanks
Nothing.
*Please note that you can only do a TBA using Vag-Com.
how do you do it on vagcom? I couldn't figure it our the other day...
Sorry to sound dumb but why do it then ? ...
