Things I have discovered about the car.
Stonepope
140
91
Great little write up, really good to read. I live top end of Ashton, near Mossley, Snake and Woodhead all very local to me and I will be out in my VZ2 as soon as it arrives later this year. You’ve probably detailed this elsewhere, but may I ask which roof bars you have for the car as I’ll be putting bikes on mine. 👍🏼
Lucky you living near those roads and scenery! No problem re: roof bars, try this link to the Thule website if you want to buy new : https://www.thule.com/en-gb/buyers-guide?c=roof+racks&q=sfFxFfCjH
I'm tight so got the 961 one's secondhand from ebay for £60 and they fit perfectly, just make sure you get the 118cm ones. I had some bars I thought would fit, checked the front one and thought all was good, hadn't appreciated that the rails are not parallel and narrow as you go back along the car. So when I went to fit them I couldn't slide the fixings close enough to attach to the rails on the rear bar, due to the cutouts underneath being too far apart. Cue urgent search online, luckily somebody close by was selling phew. For the rail fixing you'll need the 7104 Evo Raised Rail Footpack, again I got this second hand so do an ebay search and you'll find them.
Cupradev
169
100
I know, very blessed. A long time ago now, I had a Clio 16v, the original one with bonnet scoop and flared arches. That was an absolute animal on those roads, before average cameras on Woodhead. 👍🏼👍🏼🤣
Have watched a sunrise from Mam Tor recently too, spectacular. Appreciate the roof bar intel, good call on the bar length too, I had noticed how much the roof bars taper in from a style perspective, but hadn’t considered the roof bar connotations 🤦🏻‍♂️ So you’ve just saved me some embarrassment further down the line.
IanH72
301
127
Yeap, was on my lonesome. Car was awesome on Snake Pass, Sheffield too Glossop, power and grip mighty impressive. Overtaking ability is silly. I have to say with DCC set to firm the car felt more controlled than my 7.5 Golf R (no DCC on that). Had it in Individual mode, but wasn't hearing pops and bags with engine sound set to Comfort. Thought this just set the Soundaktor in the car, but must also control the exhaust valves too. Had to stop and take a photo of course. View attachment 24428
Your VZ2 looks stunning! I’m hoping to collect mine on Thursday🤞What size roof bars and which foot pack are you using as I need to order a set for a holiday end of this month?
CupraPoopra
55
45
Looks great. Are you Sheffield based? If so, I keep passing one in an evening around the Whirlow area.
Stonepope
140
91
Scroll up and the info's there, a couple of posts up in reply to Cupradev 👆👍
Reactions: IanH72
May 2, 2021
136
51
Don’t let the Mrs put car park tickets on the dash, they disappear down there between the plastic and the glass .
£4 that cost ffs
  • Wow
Reactions: Stonepope
AndyCupra93
296
127
£4 that cost ffs
That’s a fear of mine, I hate that things can be lost down car windscreen/dash void
I always display tickets on the other side of the dash, below the ledge.
IanH72
301
127
This is my first automatic car so having to get used to the driving style, I have found out that when driving in manual mode you can hold the right paddle to put it back in auto mode and if you hold the left paddle gear bot swaps straight to the lowest possible gear. I find the button on the end of the indicator stork useful to turn of lane assist etc...
CupraCraig
132
57
The paddles are terribly positioned for “manual“ driving.
I can understand aesthetically why manufacturers want to tuck them in, but they dont serve well for a spirited B road blast with a lot of steering and gear change required at the same time.
Maybe my hands are too small, but paddle extenders could be required.
Reactions: Wattser
AndyCupra93
296
127
I agree. Funnily enough the Mitsubishi PHEV courtesy car I currently have has enormous column-mounted paddles, just like a super car, and yet their only purpose is to change the level of regenerative braking!
Agnes.Surrey
772
421
Surrey
But when you use that stork to change Lane Assist settings, it also changes dash view. So I avoid using it, so I don't have to click couple of times, to get back to my dash view.
I put start/stop and lane assist on the main screen, if I ever want to switch them on/off while driving.
Ricknffc
464
302
Set seat in memory function today for first time, really easy to do just get in the position them press set and a number, you wil hear a noise. Then if the seat ever moves you just hold the number down that you selected and it puts it in that position
Reactions: Yaz2010
Gregums
115
79
If you link it to your driver profile, it will also reset with the key - very useful when I'm 6' and the missus is 4'11"!!
Reactions: Peyton
MrBowser
29
20
Finally got my Cupra!!
A question guys; there is a function where side mirrors will drop down while driving backwards, it doens't work in my Cupra, does it in yours?
Also, is there a way to stream a video on the display in car?
Gregums
115
79
View attachment 24563 View attachment 24564 View attachment 24565
Very nice. Re the mirror for reversing, check out the manual as you'll need to set it up, plus you'll need to 'select' the nearside mirror on the door switch for the reverse dipping to be active. Enjoy and Welcome to the Tribe!!!
MrBowser
29
20
Will look into it. Thanks!!!
MrBowser
29
20
I can only see the passenger mirror setup in the manual, guess the left mirror is not possible?
