The All Famous Clutch Pedal **HELP**
Havok316
Boost Junky
Jun 6, 2006
1,220
Weston-super-Mare
Before anybody moans about there being a guide Ive read it an although it gives u basic idea of what to do im assuming there are images missing or something there that isnt now.
Anyways so far ive removed the plastic stuff near the drivers footwell, Ive removed the clutch switch, now im trying to get the "safety clip" off from the end of the axel bit. Anybody have any ideas how to remove this? Its a kinda squarish metal thing over which appears to be a rounded end bit on the axel?
Also is it worth removing the drivers seat is it easy and how?
Kevgrady
420
North East
The clips just push out with a screwdriver (well they did for me anyway) :blink: , there's no need to remove th seat as thats just making more work for yourself! ;)
R953 VSE
mine was an absolute pig to get off. this pic should make it clear how it SHOULD come off.
Havok316
Boost Junky
Jun 6, 2006
1,220
Weston-super-Mare
thanks guys ive almost finished the fix now
cant get the bas*ard return spring back on. We've got the fixed pedal on, added all the clips and all we need to do is put that ferking thing back on.
any ideas? cheers
dobs5
Best method for getting the spring back in (i think) is to crush the spring up with 2 cable ties at opposite sides, offer into place, push the pedal up to it and then snip the cable ties. Make sure your head is out of the way though!!
Hope this helps
karl.w
methanol junkie
Oct 26, 2005
606
my spring is still not back in:cry: might try again tomorrow ive been driving for about a week without it
Ninja
Cupra now gone :(
Oct 1, 2005
1,182
Reading
www.peugeot-gti.net
at 100k id think it probably has been replaced..
I was thinking that i was lucky for it not to happen and then just on the way back to work at lunch and the pedal went to the floor :(
Seems stupid that it happens to every car but seat wont admit its a problem!!
Feb 25, 2007
657
stroud
good old seat
cant slag seat dealer off to much as they watch this club as i found out today
your local seat dealer is watching you
