Hi guys! I have a 08 cupra and checked the throtle valve opening with vag com and it doesn`t open 100%...In mine only opens 83.9%. Is this normal?! I already did the valve aligment with the vag com, but it`s the same...Can someone check your own car if this happens the same to you? It`s the channel 060 in "engine" and then "measure blocks".
Thanks!
Thanks!
