Tfsi Owners help
MitraShark
Newbie
Jul 6, 2006
128
Hi guys! I have a 08 cupra and checked the throtle valve opening with vag com and it doesn`t open 100%...In mine only opens 83.9%. Is this normal?! I already did the valve aligment with the vag com, but it`s the same...Can someone check your own car if this happens the same to you? It`s the channel 060 in "engine" and then "measure blocks".
Thanks!
MitraShark
Newbie
Jul 6, 2006
128
Are you haiving any problems?
No! Not at all! The car made 263 hp stock. And now it`s 322 hp. Maybe the apr fuel pump has something to do with it...The fuel pump hasn`t been recalibrated yet...Does your throtle valve opens 100%?
