flashbsd
anyway to read any info from the two cat sensors on the mk3 ibiza cupra?
Im looking at the measure labels, but cant understand which one will help me, ideally want temp pre and post cat.
Before i do a quick swap over on the cat, so i can tell if my outlet is hotter than my inlet.
Any other sensors that tell me if its running rich, or if the airflow isnt as good as it shoudl be?
thanks
lol cheers fella! much apprichated.
found a test for block 034 has a cat test in basic settings, tells you if the cat is healthy, and what temps/efficiency is like.
That should help me out :)
