Hello all,
I've owned my 2002 Mk1 1.8 T 20V (94K miles) for just over a week and have a few faults I'm hoping you can help me with. Any ideas would really help. I haven't been able to find exactly what I need in previous posts.
1. Temperature gauge and fans - My temperature gauge (on the instrument panel) only works intermittently. It usually doesn't move above 60degrees (the minimum on the dial) but has worked once in the last 10 days. Loose connection? Damaged gauge? Dodgey sensor? Which temp sensor is used for this? Can I access it to test the connections?
Extra info:
I have been able to read the coolant temperature using OBD2 and the Torque android app.
During a run from cold the temp came up to 90-97 degrees C. While driving the radiator seems to work as the coolant temperature reading (from Torque) goes down to 65-80 degrees. When idling it goes back up to 90-97 degrees. My radiator fans did not activate at 97 degrees. Should they?
2. The instrument panel LCD (clock and journey distance) loses it's memory when ignition is switched off. The lifetime mileage does not get erased (I imagine this does not rely on a 12V connection to avoid loss of the important data). I have a good understanding of electronics although I'm not very experienced with cars and repairs.
3. Rain drain holes. How can I access the drains under the windscreen please? I think the driver's side is leaking onto my pedals in heavy rain.
Extra info:
I have recently re-sealed all door panels using the advice from this forum which seems to have stopped all leaking from these areas. Carpets are drying slowly and I have moisture traps in place removing humidity.
I really hope I can iron out these troubles so I can enjoy this car with a bit more faith and confidence in it.
Thanks in advance everyone
Extra info:
Extra info:
