Temp Sender! And Boost Problem
flooky
I found today when my car was sat in traffic it had gone from 90 - 110 on the gauge??
I done VAG-COM lastnight and it came up as Temp Sender Fault so I guess this would be my problem?
Soon as I pull away and drive it goes back to 90..
Also my car hestitates on boost from around 3.5k but not all the time? On VAG-COM it showed a leak and the engine to be running lean.. Well I replaced the hose from the top of the DV and it's still does the same most times I plant it..
Looked back on VAG-COM and now there is no faults! not even the temp sender fault! Whats going on anyone know?
Saul
<b>SCN Admin</b>
May 21, 2001
4,194
mine was intermittent, replaced the sender anyway as its only £20 and 5 minutes to do
flooky
well im hoping so cos vag-com lists the temp sensor as a fault and i now dont have a fault code for the engine running lean and a leak in the system how ever i do still have the problem it strugles to get to the redline?
i'll do some more logs tonight and post them here.. hope i get a answer and get my parts tomorrow!
