Temp gauage issues
charlie_j17
Its good to torque!
Nov 11, 2009
54
BATH
My temp gauage keeps dropping of to nothing then rising up to half way again. Ive replaced the green four pin sender but its still doing it!!
What do we reckon a new thermostat required?
charlie_j17
Its good to torque!
Nov 11, 2009
54
BATH
I will check it out but its only when im driving steady, drive it hard and the gauage stays bang on in the middle.
charlie_j17
Its good to torque!
Nov 11, 2009
54
BATH
The climate panel reads 90 when up to its running temp even when the gauage is dropping off :confused:. Anybody had a faulty gauage before??
gingerben
72
this is prob ya temp senser m8, well covered, has 2 sensors in 1, 1 for dash and other for ecu i belive, check on your climate controll option number 51, mines doin the same gonna change it soon. any 1 know how much they are???
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
A genuine one can be faulty too.
To try a new dash gauge is a new dash and pairing up to the ECU via vag com/ keys pairing up.
Can't be thermostat as it is holding 90 deg.
charlie_j17
Its good to torque!
Nov 11, 2009
54
BATH
Done this as well, but no faults. Might try a new stat just for good measure for what they cost. Ive noiticed the heater gets really hot when left idle and gets abit cooler when your driving.
charlie_j17
Its good to torque!
Nov 11, 2009
54
BATH
yea it is but apart from temp senders and thermostats nobody else seems to have any problems with the temp gauage.
Mukkyman
182
mines doing same as yours mate. climate control reads 90 but dash clock sometimes bounces for 90 to 60 then half way thenback to 90.
Was hopping it was gonna be sensor but looks like the climate control reading correct temps as always.
What else could I be looking at
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
Mine does excatly the same to....does it go down when you put your foot down?
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
Oh....mine only seems to do it once its warming up, once its been running more than about 15mins and the coolant is actually about 90 it stays there and doesn't move.
I bought new green sensor last week, went to fit it at weekend and I already had a green one fitted.........I will get round to fitting it anyway but its under my intercooler pipe.
Can't think what else would cause it?
Mukkyman
182
mines was green replaced with oe green does same thing. the fact that the climate control temps is working correctly im not to worries as the sensor seems to be working as it should its just the dash temp guage. im guessing the signals gets converted for digital to analogue so the dash clock works. maybe thats brokens?
