tdi 150 cam belt.When?
Feb 12, 2006
625
North Lincolnshire.
Hi again guys.Can anyone advise when I should do the costly job and get my cam belt changed.I heard its around 60k.Mines off for its 50k service tomorrow,{150 quid rip off from the steeler just for his stamp and oil n filter change}Don't reckon i'll go there for the belt job and get taken for around 4 or 500 quid more no doubt.:cartman:
Feb 1, 2007
1,602
Nottingham
Get it done at 50k while its in there and get the water pump changed if it does not have the metal impeller type (pre 04?) they are only £30 exchange and the cambelt needs to come off to replace it.
Feb 12, 2006
625
North Lincolnshire.
Mine is April 04 so hoping it is the 1 with metal impeller.Got service done now,will have 2 look into getting it changed next time,should be ok at 49,000.Will change it well before 60k.
Feb 1, 2007
1,602
Nottingham
Pre 04 will almost certainly be plastic impellers on the water pump, unless it was changed before you got your car if it was second hand. From 04 all water pumps supplied (remanufactured) should be metal impellers on the pump. Your car can of course be made in 2003 and registered some time in 2004 so check with the supplying dealer if poss!
devonutopia
fabia-lous
Mar 30, 2004
1,200
Exmouth / Exeter
I don't believe the VAG dealers actually ever went over to metal impellered water pumps. It's something I was only able to get from my local GSF...
At 50k - sod it! Just get the oil changed, and wait until 60k. No harm in waiting, unless you come close to the 4 year secondary cambelt change recommendation....? I did mine at 40k, but then I had the engine in bits fitting a special camshaft, so was no extra work to do the belt and pump at the same time.
Ibiza FR TDI
Newbie
Sep 5, 2006
53
Down
Sorry to jump in on this thread but don't see the point in starting a new one if you guys can help me on here :)
Looking to change my cambelt in the very near future, so went into the local VW dealer with my chassis number and engine code (ASZ - PD130) and asked for a timing belt kit, and water pump (decided I might as well change this at the same time).
All was fine, he got it up on the computer with prices etc, then asked what car it was for, I said Ibiza PD130 54 reg, and he said "ah no, sorry can't supply you with these parts, you will have to go to your seat dealer (which is miles and miles away!) because there is no guarantee these parts will fit" :shrug:
So I walked into another local VW dealer on the way to work yesterday, and they said yep no problem and ordered the parts in. Got a call this morning to say are in stock now.
BUT, this has me a bit worried now, could the parts possibly be different for say a Golf/Polo PD130 ASZ then my Ibiza ASZ? Just wondering before I go and pick them up. Haven't yet paid for them.
Anyone got the part numbers I need??
Feb 1, 2007
1,602
Nottingham
I very much doubt you will have a problem I personally get all my parts from VW now because my local seat dealer is terrible. It took them 10 days to get me a glow plug! I am sure you will no probs with the parts fitting.
Glynn
Cupra_ap
Hi,
I have a Leon Cupra TDI. I was prepared for the cambelt change at 60k miles but after the service the dealer said it did not need doing on thes model until 100k???
Im seriously worried now and think I will take into to another Seat dealership.
Any one else had this advice from Seat Northampton?
Ibiza FR TDI
Newbie
Sep 5, 2006
53
Down
Glynn
Cheers :) anyone else confirm all ASZ engines will use the same parts??
LeonCupraTdi
Hi, i've just had my 60,000 service on my 04 tdi 150 Leon - the garage recommended i have the belt changed, which i plan to book it in for next week. Has anyone actually experienced problems with the belt failing around this mileage on a leon?
im tempted to leave it a bit longer as nothing has ever gone wrong with the car in the 3 years ive had it but realise its better to be safe than sorry.
