Tail lights upgrade
rohank99
37
15
How simple is it to upgrade from halogen to LED taillights? Is it a case of unplugging one and plugging in the other or is there more work to it. Looking to upgrade mine and get the nicer looking LED taillights.
LeylandVCDS
547
325
Leyland, Lancashire
Not as easy as that - you will need to run extra wires down from the high level brake light to each of the new outer, body mounted LED light clusters as the wire for the brake lights is missing in the halogen units. You will then have to go into the configuration settings of the light clusters (address 09 central electronics) with VCDS or similar and reconfigure each light allocation to LED rather than standard bulbs
rohank99
37
15
Have you done this process before? How hard was it
RiponM_27
45
8
Have you fitted the outer part? Does it need wiring or just coding
i have put an outer one, sadly the brake light doesn’t work as the halogens use the same wiring as the drl so i will have to get a harness to connect the outer to the brake light at the top.
