Suspension problem?
stezo2k
Anjuna Monkey
Mar 15, 2008
2,804
Dudley
Hi guys, i have recently started getting noises when i run over any bumps on the left side, the noise itself sounds metalic (kind of like having a toolboox rattling in boot)
The noise seems to be coming from the top left side near the wheel. Any ideas what it could be? i'm guessing its something to do with suspension
rf860
3,575
scotland
Strut mount bearings seized/worn, just had this done under warranty on my car and the sound you are getting sounds like the one i had.
stezo2k
Anjuna Monkey
Mar 15, 2008
2,804
Dudley
ah shame, the only issue i seem to have had with my car is suspension or similar things to it anyway heh
any ideas how much it would cost to fix roughly? may get some cupra bushes fitted at the same time
RUM4MO
7,966
1,059
South Scotland
Depending how accurate your decription of the fault is, it could be the ARB that has failed as your car is old enough to have had the ones with the plastic end stops. If this is the problem, then yes get all the sensible changes done to save money in the future as the cross member is dropped to replace the ARB and again to replace the TCA rear bushes. You should head for your nearest VAG indie specialist and get them to use the Cupra TCA rear bushes. One way to check the ARB is to reach in and grab the ARB and try to pull it side to side. Use search here and on www.briskoda.net - include the words ARB and you should find some pictures and more tips on what to look for etc.
stezo2k
Anjuna Monkey
Mar 15, 2008
2,804
Dudley
many thanks, ill try that :) i had a feeling it could be the bushes, had a similar problem in the past with the bushes
lc4geoff
FR TDI
Jan 12, 2008
205
Portadown, N. Ireland
Like Hartosh1 mine was making a metallic rattle, turned out drivers side spring was broken, I only found out when I jacked it up to have a look and about 2/3 of a coil fell out onto my garage floor. I'm just glad it didn't happen on the motorway!
stezo2k
Anjuna Monkey
Mar 15, 2008
2,804
Dudley
Did it sound a bit like a tool box rattling at all? If so I think you've found the problem :)
Any ideas how much it will cost me? If its a lot it may be worth me getting some new bushes at the same time
stezo2k
Anjuna Monkey
Mar 15, 2008
2,804
Dudley
Right, got it sorted
Turns out it was a suspension spring which part of it was broken off
Thought i'd mention it incase anybody else has the same problem :)
