sucking type noise after ignition on
JR750
95
Hi,
When i turn my ignition on, I can hear some sort of sucking/rotating noise from underneath the car for a second or less.
Is that normal?
dholdi
931
Preston
Is it a diesel ? My Leon tdi does the same which I guess is the fuel system priming. Done it ever since I got it so guess it is normal.
Apr 27, 2008
900
i was thinking the same thing earlier when i started my car up.
anyone tell us what it is?
mines a cupra diesel
JR750
95
Yep it is a diesel. First thought was 'Oh ****, the turbo'. Tell me its not that ?:D
dholdi
931
Preston
No I dont think it the turbo, with just the ignition on you havnt started the car so the turbo will still be stationary :D
I'm pretty sure its the lift pump you can hear which pressurises the fuel lines from the tank to the high pressure injector pump.
CJRamze
Proud Seat Owner
Jun 29, 2008
2,014
Caldicot, South Wales
Ahhh I miss that sound from my derv days,
It sounds really loud when You've had little sleep.... I can just dear it now.
Totally normal, Mine did it when I picked the car up from the dealer, only had 6 miles on the clock!
R1ch85
1/4mile - 13.935 @ 100.54
Nov 9, 2006
1,675
Bristol
mine does it too, once when I open the door, and again when i turn the ignition on. Cupra petrol :)
kojack
My wifes 1.4 petrol does it, we just thought it was the immobilizer ?
carly
46
belfast
Hi,
Is that normal?
its the water starting to run round the engine. and it only happens when you start you car . [B)]
