sub choice....
Phil_beeza
461
thought i would float this question in yet another forum:redface: just in case....
car audio security suggested these two setups:
under £300,
sub: alpine type r 10"
amp: alpine MRP M650
over £300
sub: diamond d310
amp: dls ca12
the diamond goes down to 28hz, the alpine goes down to 20hz. but the diamond is more expensive so i assume gets what you pay for....any opinions ? :)
for some doof doof dance music.....SQ first, volume a Very close second
Phil_beeza
461
thank you for the advice :) if i use the dls CA12 which can put 500w into 1 ohm, i've decided the choice of either the diamond sub above, or the alpine type r dual 2 ohm voice coil (so the amp can see that as 1ohm)
the diamond setup will cost about £340, the alpine setup will be about £315, any ideas if the diamond is def suggested to go for? i dont mind spending the extra £25 as long as i might notice the difference....!!
