stuck in 2nd gear
camt149
51
kemnay
i have a slight problem, was driving home on saturday nite pulled out of a junction, i have to addmit i was thrashing it in first slamed it into second and now i cant change gear. the gear stick is loose and wont engage any gear...
does any one have a clue gear box shagged or gearlinkage
helllllllllllp
Jib
496
31
Doncaster, South Yorks
Sounds very similar to what happened to mine. Check the gear linkages. They are situated directly ontop of the gearbox. 2 cables attach to an arm. Check to make sure the cables are fitted securely.
Otherwise, it could be a snapped clutch cable.
