Strut bolts
danielc16
cupra R dan
May 13, 2008
327
guildford
ok done the search and gave up, rite im rebuilding the front setup of the steering and surspension on the ibiza and got new bolts, wish bones, track rod ends etc... only thing is i need the strut bolts thats hold the coilover to the hub (the 2 bolts that you can adjust the camber) so i need some body to tell where and what part number it is.
i have looked on ebay and only found this:
http://cgi.ebay.co.uk/BOLT-pair-FRO...trkparms=65:12|66:2|39:1|72:2136|293:1|294:50
thats what i need but for a seat ibiza cupra R
thanks!!
danielc16
cupra R dan
May 13, 2008
327
guildford
leganed chris spent a few hours laste night trying to find them lol hopefuly i can get the rest of the stuff so their is no noises and movement in the steering, as some thing dont feel right and i rather have it all perfect for the mot
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
8 bolts;). I would replace the strut nuts as they are meant for one use, if reused the nylon part will no longer do its job.
On the mk4's the nuts are captive on the top mounts so you cant just change the nuts. You have to change the wholt top mount.
lemonslap
In The Know
Mar 14, 2009
320
Kent
i'm sure like most newer vag products but this is for a mk3 version and these have 8 (4 per side) that screw into the top mount from above, then there is a single nylon lock nut that holds the strut to the top mount.
danielc16
cupra R dan
May 13, 2008
327
guildford
just to clear a few thinga up i need the part no for these bolts 2 per a side
