Strange Noise on start up
smithsc
271
Huddersfield
Hi Guys,
This post is going to be very vague so i'll apologise before i start. When i start my 2000
20vt Sport it makes a funny noise its hard to describe and only happens on tick over, it sounds like it might be a noisey pulley / carrier is this a usual problem. I had this once on my subaru impreza and they said put some talc down and it will stop it.
Any advise is helpful as its an awful noise, if anyone lives near and is mechanically inclined feel free to pop over and have a listen :D I'm in Huddersfield West Yorks
Mr OCD
1,974
Manchester, UK
I dont mind having a listen for you... have VAGCOM as well if need any logs / codes sorting.
I'm 25mins from Huddersfield (Manchester)
CUPRAMUNKY
Hi Guys,
Mine does this to only when cold think it's the auxillary pump
smithsc
271
Huddersfield
Ok will try and describe, its not a squeel like a belt slipping, the best way to describe it is think of the brakes been down to there limit and when you press them you can hear them going round the disc waking a kinda or shhh shhh noise its like that.
Sorry its do dam difficult to describe. Its quite noisey when its cold not too bad when its warm but you can still hear it thats what makes me think it might be a pully that needs oiling
Mr OCD
1,974
Manchester, UK
On cold start or any time?
PM on way.
Mr OCD
1,974
Manchester, UK
Well an interesting evening :)
Turns out the car has been remapped which was a nice surprise... but the Lambda sensor is shot (front one) and the MAF is poorly reading 110gs... also suspect a split breather pipe under the inlet manifold.
Noise is suspected aux. belt tensioner whining a little so needs replacing at some point.
So a few jobs to do... nothing expensive or difficult though :)
Took Scott out for a spin in the LC after to show him how a remapped car should feel and he was very impressed :)
smithsc
271
Huddersfield
i was indeed its a beautiful car in great nick i'm very grateful you had a look a found out what the problems were hopefully getting sensor fitted this week just hope maf hasn't gone as well looking forward to coming back and getting her fixed once again thank you
Mr OCD
1,974
Manchester, UK
Cheers mate :)
Anytime [B)]
Mr OCD
1,974
Manchester, UK
Engine Fault Codes are requested:
VAG-COM Version: Release 409.1-US
Control Module Part Number: 06A 906 032 T
Component and/or Version: 1.8L R4/5VT 0003
Software Coding: 05510
Work Shop Code: WSC 06441
2 Faults Found:
17524 - Oxygen (Lambda) Sensor Heating: B1 S1: Open Circuit
P1116 - 35-00 - -
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-00 - -
Mr OCD
1,974
Manchester, UK
Quick Logs done ...
Code:
Monday	1	February	2010	18:11:16
06A 906 032 T		1.8L R4/5VT         0003
	Group A:	'003				Group B:	'118				Group C:	'115
		Idle speed	Air mass in	Throt Angle	Ignit Angle		Engine Speed	Air Temp In	Boost Dut Cyc	Actual Boost		Engine Speed	Engine Load	Spec. Boost	Actual Boost
	TIME	700-820 rpm	2.0-4.5 g/s	0.2-4.0%	0-12 BTDC	TIME	700-6800 RPM	<=110 C	0-100% 	<=1800 mbar	TIME	700-6800 RPM	15-150%	990-1800 mbar	<=1800 mbar
Marker	STAMP	 /min	 g/s	%	 °BTDC	STAMP	 /min	°C	%	 mbar	STAMP	 /min	%	 mbar	 mbar
	0	1800	24.92	100	9.8	0.4	1920	22	100	1210	0.8	2080	79.7	2070	1340
	1.31	2240	41.83	100	3.8	1.71	2400	23	100	1640	2.11	2560	105.3	2140	1760
	2.51	2760	62.03	100	7.5	2.91	2920	23	100	2020	3.31	3160	162.4	2210	2150
	3.71	3400	91	99.6	3	4.11	3640	24	97.6	2260	4.51	3880	182	2160	2240
	4.91	4080	102.92	100	4.5	5.31	4280	27	98	2150	5.71	4520	172.9	2130	2080
	6.11	4720	111.67	100	5.3	6.51	4880	31	100	1950	6.91	5080	160.2	2100	1890
	7.31	5280	111.94	100	7.5	7.71	5440	34	100	1800	8.11	5600	144.4	2080	1750
	8.51	5760	112.78	100	11.3	8.91	5920	38	100	1700	9.31	6080	135.3	2040	1670
	9.71	5600	6.31	5.9	23.3	10.09	4600	36	0	1150	10.49	4680	7.5	990	1080
	10.89	4560	7.75	7.1	21	11.3	4440	34	0	1050	11.69	4280	9	990	1050
Code:
Monday	1	February	2010	18:12:32
	Group A:	'020				Group B:	'031				Group C:	'032
		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization		Voltage	Voltage	Bin. Bits	Bin. Bits		Idle O2 Adapt	Run O2 Adapt
	TIME					TIME					TIME	-10.1	-10.1
Marker	STAMP	 CF	 CF	 CF	 CF	STAMP	 V	 V			STAMP	%	%
	0	5.3	0	0	0	0.4	0.66	0.335	        	        	0.8	0	14.8
	1.2	9	10.5	5.3	10.5	1.6	0.675	0.74	        	        	2	0	14.8
	2.4	9	10.5	8.3	9.8	2.91	0.855	0.915	        	        	3.31	0	14.8
	3.71	7.5	8.3	8.3	9.8	4.11	0.895	0.925	        	        	4.51	0	14.8
	4.91	6	6.8	6.8	7.5	5.31	0.9	0.895	        	        	5.71	0	14.8
	6.11	3.8	4.5	4.5	6	6.51	0.915	0.875	        	        	6.91	0	14.8
	7.31	2.3	3	3	3.8	7.71	0.91	0.86	        	        	8.11	0	14.8
Code:
Monday	1	February	2010	18:13:48
	Group A:	'120
		Engine Speed	Spec Load	Curr Load	ASR Status
	TIME	700-6800 RPM	0-399 Nm	0-260 Nm	active yes/no
Marker	STAMP	 /min	 Nm	 Nm
	0	3160	399.8	13.7	ASR OFF
	0.4	3200	399.8	82.3	ASR OFF
	0.8	3360	399.8	154.8	ASR OFF
	1.2	3560	399.8	198	ASR OFF
	1.62	3800	399.8	219.5	ASR OFF
	2	4040	399.8	268.5	ASR OFF
	2.4	4240	399.8	245	ASR OFF
	2.8	4440	399.8	254.8	ASR OFF
	3.2	4600	399.8	258.7	ASR OFF
	3.6	4800	399.8	247	ASR OFF
	4	4920	399.8	260.7	ASR OFF
	4.4	5080	399.8	266.6	ASR OFF
	4.8	5240	399.8	247	ASR OFF
	5.22	5400	399.8	252.8	ASR OFF
	5.61	5520	399.8	235.2	ASR OFF
	6.01	5640	399.8	227.4	ASR OFF
	6.41	5760	399.8	235.2	ASR OFF
	6.81	5880	399.8	227.4	ASR OFF
	7.21	6000	399.8	219.5	ASR OFF
	7.61	6120	399.8	221.5	ASR OFF
	8.01	6240	399.8	215.6	ASR OFF
	8.41	6320	399.8	209.7	ASR OFF
	8.81	6400	399.8	211.7	ASR OFF
	9.21	5720	399.8	0	ASR OFF
	9.71	5000	399.8	166.6	ASR OFF
	10.11	4880	399.8	39.2	ASR OFF
	10.51	4880	399.8	0	ASR OFF
	10.91	4800	399.8	0	ASR OFF
