tmg101
Hello,
I had a service and MOT about a month or so ago. The result of which was that the front pads were replaced.
I'm now getting a metal on metal scraping noise coming from the wheel.
I'm hoping its just a stone trapped between the two plates.
the noise get worse when I slow down.
I'll be abit unhappy if anything more serious espically as it passed its MOT just over a month ago.
Anything obvious that I can check myself ??
Thanks,
Andy.
Does it pull to one side or the other noticeably when you brake? Take it for a local run, then jump out and see if one wheel feels considerably hotter than the other - be careful, don't burn yourself! I'm just wondering if you have a caliper binding a little.
Not that I've noticed.
Might be me going mad but the car has started to look a little lower on one side. To the point where if I approach from the passenger side it looks like I've got flat on the drivers side.
It maybe related to that.
Are the disks smaller on the back ?
When I check the back the distance between the disks and cover plate behind it is about 1/4 inch, whereas on the front there is no gap at all.
