Hey!
I'm new here, been lurking and using the search function for the last month, and I have found everything very useful and informative!
Recently purchased a mk1 2001 leon TDI SE 110, with the ASV engine.
However I have a small issue, sorry if this has been covered but i can't find a problem on here the same as this;
When I start the car in the morning from cold it wont idle properly, for the first few minutes it revs up and down between 800-900rpm (purr purr purr etc.) It sound as if its compensating for load like when you turn lights on or AC in some cars.
I believe this not to be the case as i have tried every combination of systems running at start up. If you tweak the pedal a tad it is fine. It is also fine when up to temperature where it idles smoothly at 900rpm.
I wondered if there was some kind of cold start valve or a MAF/EGR problem?
