Stock LC 180 Logs
Aug 27, 2012
581
Maidstone, Kent
Does this look ok, according to the logs its getting 143g/s? This was in 2nd from around 2000rpm to the redline, or as close to it as i could get before pressing stop
My only mods are a forge split r valve and the n249 bypass
Code:
Tuesday	2	October	2012	14:30:02
06A 906 032 MJ		1.8L R4/5VT         0003
	Group A:	003				Group B:	Not Running				Group C:	Not Running
		Engine Speed	Intake Air Mass	Throttle Drive	Ignition
	TIME			Angle Sensor 1	Timing Angle	TIME					TIME
Marker	STAMP	/min	g/s	%	°BTDC	STAMP					STAMP
	0.01	2120	18.47	13.7	22.5
	0.4	2280	39.58	85.1	17.3
	0.8	2520	54	100	14.3
	1.2	2800	71.58	100	12
	1.71	3200	78.36	100	12.8
	2.11	3520	87.81	100	14.3
	2.51	3840	93.5	100	16.5
	2.93	4200	104.44	100	16.5
	3.31	4560	110.75	100	13.5
	3.82	4920	121.78	100	17.3
	4.22	5280	131.33	100	18
	4.62	5600	138.53	100	12.8
	5.04	5880	142.97	100	16.5
	5.54	6200	143.89	100	15.8
	5.94	6440	143.44	100	18.8
Aug 27, 2012
581
Maidstone, Kent
Changed some pipes today for silicone ones like my TIP and so on, Done a quick log in 2nd just from 2500rpm to 6300rpm and went to 149.44 g/s im guessing this was mainly from changing my TIP?
Code:
Thursday	4	October	2012	17:29:48
	Group A:	'003
	0.4	2520	14.08	12.2	24
	1.2	3400	90.06	99.6	8.3
	2.01	4960	125.39	100	20.3
	2.83	6320	149.44	100	22.5
Aug 27, 2012
581
Maidstone, Kent
No mate still waiting for my new PCV pipe to go from the crank breather down.... Currently out of stock :-( so I'm holding on lol but I see the difference in TIP it's flat where it goes on the side of the turbo intake isn't it
