stereo systems....
alexoakes
133
Lincoln
Jarvista said:
So is it possible to wire two of these converters in to run two amps? Or can you buy a converter with four rca outputs?
As far as I know you can't buy one with four RCA outputs. There's no point anyway. 2 convertors, 1 converting the front signal (somewhere behind the head unit) and one at the rear converting the rear speakers. An RCA lead from the front for the front signal and a short RCA from the rear for the rear signal, easy!!![B)]
Deleted member 12147
Cheers, at the mo i'm still in two minds whether to buy two of these converters or just to wire an after market HU under the steering wheel. Does anyone know if the wiring from the back of the ibiza standard HU will plug directly into a sony iso plug?
davidol
New ghetto whip :)
Aug 17, 2004
1,978
Cardiff
yep the ibiza uses iso plugs, the industry standard. On a personal recommendation go with the alpine powered hi-low level convertors, much much better than the autoleads offering
oz_borne
Return of the mac
Mar 31, 2006
77
Quedgeley, Gloucester
You can use them, but then you loose power to all sorts!!!
I just piggy backed the power from the standard head unit (on the recommendation of rprevious owner) and then put my head unit under the steering wheel.
The speaker leads are then a little short, but will reach, you can easily extend this iso block if you need to, but i couldn't be arsed!!!!
Currently have...front components running off amp in boot, and rear speakers upgraded to JBL. Will, in time, change the rears to 6 x 9's running off head unit and buy another amp to power my sub.
Sounds good up front right now, but need some meat in the back.
oz
