stereo probs
ScottyDog
146
Cambridge
just fitted a new stereo in my car, but I'd cut the old aerial plug off (cos I needed a male connection, not female), therefore just having a wire with no plug on the end. I've bought a new plug, that basically crimps on the end of the stripped cable. I'm now getting a crackling in the background of every station. Any help anyone? Also, I get no AM reception. Although I didn't get it on my original stereo anyway. Cheers!
andyj
There's no F in Quality..
you could have just bought an adaptor to convert from female to male ! ;)
but seeing as you've already cut the cable, that's no help!
it sounds like you've got a short somewhere between the centre core of the aerial co-ax lead, and the outer braid...... this will give you the crackling.
ScottyDog
146
Cambridge
just re-wired my aerial (again). I get a perfect signal with engine off, but as soon as I'm driving, I get the crackling back. Also get no AM at all. Could it be that I need an aerial booster? please help as its really annoying. cheers!
midgetgem
144
Carlisle
do you have the standadr ariel or is it a stubby chrome one? if you have the oe ariel then clean the threads and degrease it, might make all the difference
Brummy
Nazi Moderator-Bot
Mar 6, 2005
4,275
Moved to the DarkSide
crackling could be picked up from it needing to be 'supressed'... a form of attenuation to stop elctrical interactivity between the aerial and other nearby wires etc :)
SWANSWAY CUPRA Dealership
