steaming up
ScottyDog
146
Cambridge
Just a quick question. Does anyone else have the same problem I do. When it rains, my windows really steam up bad, even with my fans on full blast. Also, in the cold weather, the ice, is does too, & I can barely see where I'm going.
G223
303
try opening your front windows a tiny tiny tiny bit, like a 1mm gap
BrownCupra
85
Aye thats a good trick to use mate....
If that car is steaming up really really bad on the inside then there must be water inside the car! i.e a smal rusty whole letting water inside the car or a foobard window seal!
If its just a lil bit of steam before the engine gets warm to clear the screen open the window and dont breathe for a bit :lol:
crezz
pedro motorsports
Jun 30, 2007
4,397
Woolacombe
its all because of the magic,
i also dont breath in mine either,, soon passes
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
give the glass inside and out a damn good clean
clean smooth glass won't let water stick to and hence no condensation :):)
if you have a high content of damp inside the car (leak) it will be worse mind
Dolly_Gti
G60 spooling up.
Aug 15, 2006
1,412
china town
beat me to it, keep the glass clean moisture sticks to dirt. i came out of work today and nearly everyone had to scrape the ice off their screen, but mines wasnt too bad some screenwash and wipers later i was good to go.
im wondering if Rain-x stops ice forming as easily??? i mean it is alcohol based by the smell of it.
old 'uns
Modern Life is Rubbish...
Mar 20, 2003
1,627
walsall
if you're brave you'll lift the carpets & see how wet they are underneath. bet there's a leak or a bung out somewhere if you get steamed up all the while.
don't think Rain-X helps that much, if it's icy, it's icy and you still need to scrape
silverline1
a lot of water comes down the scuttle and rests under the passenger footwell
common problem, and the worst to trace
mines steams up from time to time also
ScottyDog
146
Cambridge
I have a hole in the plastic tray under the scuttle panel, so the water runs down the windscreen, in the hole, straight into the air intake box, & drips out where the heater resistor plugs in, right onto the passenger footwell!
