Welcome to our new sponsor Lecatona, a brand dedicated to enhancing performance for VAG group sports cars, including SEAT, Audi, Volkswagen and Škoda. Specializing in High Pressure Fuel Pump (HPFP) upgrades.
Just a quick question. Does anyone else have the same problem I do. When it rains, my windows really steam up bad, even with my fans on full blast. Also, in the cold weather, the ice, is does too, & I can barely see where I'm going.
If that car is steaming up really really bad on the inside then there must be water inside the car! i.e a smal rusty whole letting water inside the car or a foobard window seal!
If its just a lil bit of steam before the engine gets warm to clear the screen open the window and dont breathe for a bit
beat me to it, keep the glass clean moisture sticks to dirt. i came out of work today and nearly everyone had to scrape the ice off their screen, but mines wasnt too bad some screenwash and wipers later i was good to go.
im wondering if Rain-x stops ice forming as easily??? i mean it is alcohol based by the smell of it.
if you're brave you'll lift the carpets & see how wet they are underneath. bet there's a leak or a bung out somewhere if you get steamed up all the while.
don't think Rain-X helps that much, if it's icy, it's icy and you still need to scrape
I have a hole in the plastic tray under the scuttle panel, so the water runs down the windscreen, in the hole, straight into the air intake box, & drips out where the heater resistor plugs in, right onto the passenger footwell!
