Starter Motor Problem
dirtbiker
274
Southampton / Nottingham
I'm having a bit of a problem with my 1.4 (AEX Engine) Ibiza:
Sometimes when the engine is cold the starter motor will not engage. Turning the key just results in a whirring noise. A few tries at starting it gets the starter to engage and the engine turns over and fires fine but I'd obviously rather it didn't do this!
I'm guessing that there's just some sticky oil in the system (which is why it never does this when the engine's warmed up). Is it just a case of stripping the starter motor from the block and giving everything a good clean or is there something more sinister I should be aware of?
Cheers :)
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
might be a bit of crud stopping it from engaging
did I send up a spare starter with that engine? i can't remember
torquesport
Lets Torque Diesel
Jan 19, 2008
137
Stone, Staffordshire
no really straight forward really also check its being earthed and why you have it out you can test it just make sure its earthed. read about a few people with this problem if you undo the 2 bolts on the motor and the one on the solonoid and give the cogs abit of grease as they can sometimes stick. or maybe the bushes are goin in it
dirtbiker
274
Thanks all, you did send a spare mOrk but it was very different to the one I took off!
Just unbolted it, sprayed some WD40 on the moving parts and fired the solenoid a few times (on the bench top). Seems to have done the trick!
