standing still
woza1
hi everyone just to let you know im new on here so please go easy on me and see if you can help me in the meantime.
I drive a 1.8t leon mk1 most of the time the power delivery is great but sometimes when i put my foot to the floor youd think i was standing still. Ive checked the car on vag com no codes but anoying non the less.
Yesterday i was blown away by a cleo 172 so i took some logs in third as ive seen on here but dont understand them so any help would be appreciated .
Group A: '003
Idle speed Air mass in Throt Angle Ignit Angle
TIME 700-820 rpm 2.0-4.5 g/s 0.2-4.0% 0-12 BTDC
MARKER STAMP /min g/s % °BTDC
0.7 720 3.78 1.6 0.8
1.91 1200 6.28 3.9 0
3.02 2280 28.03 17.3 0.8
4.02 1640 16.53 10.6 12.8
5.13 1880 24.28 16.1 14.3
6.23 2840 40.06 19.6 21.8
7.34 2920 9.72 3.9 23.3
8.35 2360 29.08 15.7 18.8
9.45 2560 19.19 11.4 24
10.46 2680 17.86 11 26.3
11.57 2800 18.86 11.8 27
12.67 2280 7.33 5.1 29.3
13.78 2200 46.89 100 6.8
14.88 2600 67.14 100 6.8
15.89 3000 73.94 100 9
16.79 3360 88.33 100 7.5
17.7 3720 93.44 100 8.3
18.6 4080 103.44 100 9
19.61 4480 114.22 100 9.8
20.82 4920 126.44 100 11.3
21.92 5360 138.42 100 11.3
23.14 5760 152.64 100 9.8
24.15 6080 153.89 100 12
25.15 6360 152.78 99.6 14.3
Group B: '020
Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization
TIME
STAMP CF CF CF CF
0.02 0 0 0 0
1.1 0 0 0 0
2.21 0 0 0 0
3.32 0 0 0 0
4.42 1.5 0 0 1.5
5.53 0.8 0 0 0.8
6.64 0 0 0 0
7.64 0 0 0 0
8.65 0 0 0 0
9.75 0 0 0 0
10.86 0 0 0 0
11.97 0 0 0 0
13.07 0 0 0 0
14.08 0 0 0 0
15.18 0 0 0 0
16.19 0 0 0 0
17.09 0 0 0 0
18 0 0 0 0
18.9 0 0 0 0
20.02 0 0 0 0
21.13 0 0 0 0
22.32 0 0 0 0
23.44 0 0 0 0
24.55 0 0 0 0
Group C: '115
Engine Speed Engine Load Spec. Boost Actual Boost
TIME 700-6800 RPM 15-150% 990-1800 mbar <=1800 mbar
STAMP /min % mbar mbar
0.4 720 23.3 1000 990
1.51 840 28.6 1000 990
2.61 1640 51.1 1000 990
3.72 1920 44.4 1000 1050
4.83 1600 62.4 1000 1070
5.83 2480 64.7 1030 1180
6.94 3320 30.8 1000 1200
8.04 2240 59.4 1000 1050
9.05 2480 45.1 1000 1090
10.16 2680 39.1 1000 1050
11.26 2760 36.8 1000 1040
12.27 2680 15 1000 1050
13.37 2120 84.2 1740 1130
14.48 2440 121.8 1730 1600
15.59 2880 127.8 1700 1690
16.49 3240 130.8 1680 1670
17.4 3600 135.3 1680 1690
18.3 3960 133.1 1720 1670
19.21 4320 133.1 1710 1640
20.42 4800 132.3 1710 1640
21.52 5200 135.3 1730 1680
22.74 5640 138.3 1730 1710
23.83 6000 133.1 1660 1660
24.85 6240 126.3 1610 1570
25.75 6480 12.8 1000 1380
Group A: '118
Engine Speed Air Temp In Boost Dut Cyc Actual Boost
TIME 700-6800 RPM <=110 C 0-100% <=1800 mbar
STAMP /min °C % mbar
0.03 720 45 0 990
1.11 720 45 0 990
2.21 1440 45 0 1000
31.19 880 46 0 990
32.28 1520 45 0 1030
33.39 1400 45 0 1070
34.39 2360 43 0 1210
35.5 2880 42 0 1120
36.61 2200 42 69.4 1190
37.61 2720 42 40.8 1350
38.82 3320 41 24.7 1340
39.93 2520 40 95.7 1240
41.03 2920 41 65.5 1660
42.14 3360 41 65.1 1650
43.24 3840 42 65.1 1630
44.46 4320 44 66.3 1620
45.57 4760 45 67.8 1620
46.47 5120 47 72.2 1600
47.58 5520 49 74.5 1670
48.67 5880 51 74.5 1580
49.79 6280 52 71.8 1580
Engine Speed Spec Load Curr Load ASR Status
TIME 700-6800 RPM 0-399 Nm 0-260 Nm active yes/no
STAMP /min Nm Nm
0.4 720 399.8 0 ASR OFF
1.41 720 399.8 0 ASR OFF
2.61 1280 399.8 0 ASR OFF
31.58 1360 399.8 70.6 ASR OFF
32.68 1360 399.8 80.4 ASR OFF
33.69 1720 399.8 117.6 ASR OFF
34.8 2760 399.8 117.6 ASR OFF
35.8 2600 399.8 0 ASR OFF
36.91 2360 399.8 141.1 ASR OFF
38.01 2920 399.8 156.8 ASR OFF
39.22 3280 399.8 0 ASR OFF
40.33 2600 399.8 201.9 ASR OFF
41.34 3040 399.8 227.4 ASR OFF
42.44 3520 399.8 231.3 ASR OFF
43.64 4000 399.8 227.4 ASR OFF
44.86 4440 399.8 225.4 ASR OFF
45.87 4880 399.8 221.5 ASR OFF
46.77 5200 399.8 221.5 ASR OFF
47.98 5680 399.8 213.6 ASR OFF
49.08 6040 399.8 203.8 ASR OFF
50.09 6320 399.8 186.2 ASR OFF
51.29 5840 399.8 0 ASR OFF
52.19 5320 399.8 0 ASR OFF
Group C: '122
RPM Torque Torque
TIME
STAMP /min Nm Nm
0.7 720 399.8 0 No Torq Red
1.81 880 399.8 58.8 No Torq Red
2.92 1120 399.8 0 No Torq Red
31.88 1640 399.8 86.2 No Torq Red
32.99 1400 399.8 100 No Torq Red
33.99 2000 399.8 119.6 No Torq Red
35.2 3040 399.8 70.6 No Torq Red
36.2 1960 399.8 115.6 No Torq Red
37.31 2560 399.8 141.1 No Torq Red
38.42 3120 399.8 150.9 No Torq Red
39.62 3080 399.8 39.2 No Torq Red
40.63 2760 399.8 225.4 No Torq Red
41.73 3200 399.8 235.2 No Torq Red
42.84 3680 399.8 235.2 No Torq Red
44.06 4160 399.8 227.4 No Torq Red
45.25 4640 399.8 223.4 No Torq Red
46.17 5000 399.8 221.5 No Torq Red
47.17 5360 399.8 219.5 No Torq Red
48.28 5760 399.8 209.7 No Torq Red
49.39 6120 399.8 194 No Torq Red
50.48 6280 399.8 0 No Torq Red
51.59 5640 399.8 0 No Torq Red
52.49 5200 399.8 0 No Torq Red
hope ive done this right if not could you let me know thanks
andycupra
status subject to change
which leon is it?
cupra?
cupra R
sport?
or just a 1.8t?
also, the clios are actually a pretty quick car. they are significantly lighter so they are surprisingly quick by comparison.
has your car had any mods?
is the, hesitation after you have lifted off and reapplied the throttle?
DV could be the cause?
woza1
its a leon 1.8t only mod is a bmc carbon filter.Its not just bieng done by a clio that does it when you put your foot to the floor it just seems to bog down sometimes and othertimes it just seems to fly.Its going to get booked in for a remap but i was wanting to know if everything looked alright before i went ahead.
woza1
yes it was like this before the new filter and it has a baily dv30 on i was hoping that would sort it out obviously not thought the logs might show something up to someone who new what they were looking at.But if its not showing anything unusual ill book it in at bells
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
Personally, I'd want to find any potential problems before putting the car under the increased stress of a remap. Remapping the engine will definitely highlight any existing problems, but might make things worse than they need to be.
For what it's worth... I'm sure I've read other comments on this forum about that DV causing problems. Might be worth a search....
woza1
no its not drive by wire.
cleo and me head to head till about 80-90 then he just started to pull away slowly but surely.bet he was laughing his t*t* off
SWANSWAY CUPRA Dealership
