Standard stereo fitting anyone ?
tonyvodka
Newbie
Jul 20, 2006
55
Just wondered if anybody had taken the stereo out for any reason and if so i was wondering what the connections on the back are , are they just the standard seat/ford iso plugs ?
Just asking as i want to put in a new bluetooth handsfree and need to make sure i buy the right stereo adaptor
Tony
conzy
59
It is not standard iso if you need an adapter to give you iso connectors you need an autoleads adapter SOT-076 that is what I used to connect my Parrot kit. Is it a parrot kit you are fitting?
tonyvodka
Newbie
Jul 20, 2006
55
Yeh its the parrot 3200 ls i'll be fitting
Cheers for the reply
Are they easy to fit as in no cutting of wires needed etc ?
Tony
conzy
59
You don't need to cut any wires but you will need a to sort out a switched ignition live this can be done by bringing a wire accross from your fuse box or by using a Autoleads 06 Sense box which creates one. It is just a box you connect into the power lead going to your parrot brain.
You will need the stereo out and the glove box as I found the only place to put the brain is over on the far passenger side there is not a lot of room. I also took out the climate control above the stereo to give me more room to feed the leads.
Oh and you also need to unclip the AUX from the original stereo loom and plug it into the Autoleads one that goes into the back of the stereo. I learned that after I had put everything back together!:headhurt:
Davros
This may help with the Pinout
I got a switched ignition by tappint one of the CD changer wires from the head unit for my Subwoofer - its a lot easier than running a wire to the fusebox.
tonyvodka
Newbie
Jul 20, 2006
55
cheers for the replies , will fit it over weekend , sounds straight forward enough ................ famous last words :)
tonyvodka
Newbie
Jul 20, 2006
55
Well i tried and failed :(
Managed to get stereo out after a fight , was not as easy as i thought it would be
Then hooked up my parrot ls3200 to my autoleads adapter SOT-076 . Stereo was fully working etc but no power to my ls3200 .
Am i right in saying i need to run the orange 12v ignition wire from the autoleads adapter SOT-076 to a switched live point in the car before it will work at all ?
Hope i aint blown anything up as i was tinkering around for ages with it
Cheers for all your help everyone
Tony
tonyvodka
Newbie
Jul 20, 2006
55
Do you remember which wire it was from the diagram? My Stereo has constant power, and this sounds easier than finding another source..
its number 4 on part c of the diagram mate ( switched live )
This is ok if your using it for the remote wire on a sub as the stereo needs to be on for the sub to work ......... but not so good if you use it for a bluetooth kit like i have , as the stereo HAS to be powered on for the bluetooth kit to obtain power . Wish i had ran a switched live direct to the fusebox now .................... will get round to it sooner or later im sure :(
conzy
59
If you want the easy option get one of these - autoleads 06 sense this creates a switched live feed without having to source it at the fuse box, I used it and it is doing the job well
leonfr170
126
anyone here got a different stereo fitted? im planning to get my pioneer single din sat nav unit transplanted in along with the ipod interface and bluetooth parrot kit. it anyones had something like this done id love to see pics, i will post mine next week once i actually have the car!!!
can't wait to get it, i've got an old bmw 5 series right now but the seat is going to be as powerful and nearly 600kg lighter - should be a little bit more nippy!
fishpie
Does anyone know if the SOT-076 will also work for the Bury CC9060?
