Standard airbox modded for open cone filter
B3LSY
Modded a standard LCR airbox today for a open cone air filter (mines a HKS)
B3LSY
;)loud!! but sounds better with the little top section off,just keeping the top on to keep the cold air to the HKS
B3LSY
my mate kenny at AmD had it on his escort cossie,the diameter is pretty much the same as the maff just need a silcone sleeve and your in business
Scotty_b
Leon Cupra 300R
Jun 3, 2004
6,026
66
Hertfordshire
Looks nice mate, have you tried taking the weather strip off the back of the engine to get a bit more sound and a bit better air flow in the engine bay?
B3LSY
the bonnet seal you mean? if so only just put that on to keep the engine clean lol
Scotty_b
Leon Cupra 300R
Jun 3, 2004
6,026
66
Hertfordshire
No the one at the back mate, theres a few threads on here about it, with an open filter it does help when your on the road (but then if you have the weather strip on it may counter act).
vee_dub_modder
Volkswagen racing tech-pt
Feb 19, 2008
406
Midlands
I was thinking of doing that but behind the bumper, turns out some of the rb**det engines (skyline) use the same size pipework so that mushroom bolts right on! though i heard they kill hot wires???
let me know how that works out long term!!
lee_woollett
285
northampton
I'm going to buy a universal filter today and do the same to mine. Its cheaper than buying a full induction kit and means i can still use the normal cold air feed. I was thinking of getting yellow airfilter and hoses but i think i'm going to break up all the yellow with some nice blue hoses and filter. Pics to be uploaded when done.
D.K
LCR 225
Oct 24, 2007
6,408
se london
Just make sure the filler you get does'nt need oil, Also the OE feed pipe very small personally I would atleast chang the feed pipe to a 3" one
lee_woollett
285
northampton
One thing i've noticed on my airbox is that under the MAF entry in the lid, there seems to be another pipe, is this a crankcase breather or something else? if it is, where is yours as i can't see it anywhere in the pics. I know halfrauds do some small crankcase vents quite cheap.
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
You can use a filter. but tbh the fumes from the crankcase are toxic, so you really don't want any of that coming into the car at all.
You could route the pipe downwards under the car maybe?
lee_woollett
285
northampton
it goes into the lid next to where the MAF is so this will be the part of the lid that has to be cut away to allow the air filter to be in the same position as yours. If i can't see of anywhere to put it i guess i'll try to feed it down under the engine, the hose is about 2 foot in length and come from down the bottom front side of the engine. I guess i could always drill a small hole in the bottom plate on the filter and feed it into it.
