Standard Actuator Opening Pressure...
EZ Tutty
417
Derby
www.eztutty.co.uk
Hey,
I've had search but struggling to find the info i need...
I just want to know at what pressure should the standard k03 actuator begin to open?
I've made a small test rig up, and mines beginning to open at 0.5bar (7psi), is that correct?
EZT :)
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
usually 5-7psi... you will find the effective opening pressure if you electrically disconnect the n75 valve and drive and look at your gauges
EZ Tutty
417
Derby
www.eztutty.co.uk
cheers bill.
Yeh disconnecting my N75 was my first thought, but my gauges are under the stereo, and i've tried watching them whilst driving before... not good lol.
Instead i used a large syringe, a small pressure gauge and some fittings i found at work :)
Collie
so what would happen if you disconneted the n75 and adjusted the wastegate to say 15psi like a stg 1 map. ??? could the n75 be made redundant, does a map allow for such boost in lower gears etc?
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
limp mode is what will happen...
there is no where near that level of adjustment in a std actuator, couple or three psi max I think
