Stage 2+ Aggressive Settings
adam23
190
You would also need a genuine Ross Tech cable and download the Vag Com software to data log the altered settings on your car. The cable is not cheap though.
Donnyboy
The Candy Man
Mar 15, 2005
1,558
renfrewshire
I didn't realize you had to have Vagcom to do this?!?!?!
I thought most people just changed the setting to suit different conditions?
robdf2
Yellow is the best
Feb 21, 2006
3,605
location , location
What he means is you need vag com to log your vehicle to see what the Revo changes have done to your car , AFR mix , timing ect , so you can see if using aggresive settings is having a negative effect on your car or maybe causing other problems somewhere else like lack of boost ect.
Donnyboy
The Candy Man
Mar 15, 2005
1,558
renfrewshire
Ah, I see what is meant now. Your best to have Vagcom then.
adam23
190
Sorry thats what I meant, vagcom would be useful if adjusting the settings with SPS+ to monitor the car.
