SRS fault codes
tashacupra
Next up "twin scroll"
Jul 26, 2007
303
suffolk
hi just had a coil go and whilst doing an engine fault code check i thought i may as well have a look through the rest of the menu on the fault code reader, in the SRS section it displayed 2 codes which are 01218 and 01217. I have done a searh but cant seem to find out what these are. Anybody got any ideas :confused:
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
01217 032
Side airbag igniter - driver side-N199
Resistance too high
01218 032
Side airbag igniter - front passenger side-N200
Resistance too high
tashacupra
Jul 26, 2007
303
suffolk
spot on m0rk, i had a feling it was somethng to do with them because i am running aftermarket front seats for track use, so they are unpluged at the mo.
tashacupra
Jul 26, 2007
303
suffolk
yeh i had a feeling the others would not fire but i was not aware you could disable the unpluged ones thats very helpful thanks i will look into doing it.
.vader.
21
Aberdeen
Hey guys,
I got fault code 01217 in VCDS lite on my mk1 LCR, which says resistance too high, intermittent.
Does anyone know if its safe to clear the fault code, as on ross tech site it says under certain circumstances this can fire the airbag.
This advice seems to relate to specifically a short to ground or positive, but mine only says resistance too high which i reckon might be due to the connector under the seat being loose?!
Any thoughts/advice would be great,
cheers
