Spluttering, limp mode, drinking petrol!
D10RDE99
can any please shed some light on my problem:(
mk3 ibiza cupra, st1 revo'd,forge dv, fmic, twister induction kit,
few days ago whilst drivin on the motorway aprox 60 - 70 mph my car ( 2001 ibiza cupra) started to splutter and normally peaks at 18 psi now only gets to 5 psi, triple checked pipes and found no leaks anywhere, quite a bit of white smoke/steam coming from exhaust even at idle, altho it does smell like petrol and has left a black mark on the drive under the tailpipe, been to the local garage and they say its the cat, oh and the car is drinkin petrol like its goin out of fasion:(
thought i'd ask you guys that you thought as you seem to know more about these cars the the local grease monkey:D
so
1, is it possibly the cat
2, wheres the best/cheapest place to get one
many thanks in advance:p
Mat
IIRC you should smell rotton eggs if cat
usual checks are MAF, coils, plugs
someone else may give other suggestions
oh, and run VAG COM
D10RDE99
xxxxxxxxxxxxxxxxxxxxxxxxx
would the faulty maf cause it to over fuel enough to leave black marks on the floor tho, if i unplug the maf and take it round the block will it drive normally (if it is the maf thats faulty obviously:D )
Adam R
Diesel ISN'T a Dirty word
Mar 5, 2007
2,851
lee in the solent
yes that is right.
D10RDE99
cool hopin thats all it is, and that the garage is wrong:D
thanks for all comments ppl
D10RDE99
quick update=
just unplugged maf and took for a spin (approx 1.5 miles) felt much smoother and more responsive up until i hit 5 psi of boost and then its like hittin a brick wall:(
oh and its cuttin out if i dip the clutch for more than 3 seconds, and strugglin to keep runnin at idle
help needed
cus
... Vag only!
Feb 8, 2004
1,713
Middlesbrough
www.nemm.co.uk
it'll be in limp mode. will have to run vag-com on it and see what faults it brings up.
alternatively, and at your own risk. you can disconnect the ground cable on the battery for half an hour, and that will clear the faults. you can then run your car with the maf disconnected and see if thats at fault. and then reconnect it. but i would only do this as a last option to test the maf.
there will be a reason why its in limp mode so i would see if there is anyone in your area with vag-com first
D10RDE99
i haven't got vag com, how much will a garage charge me to vag com it cause startin to annoy me now,
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
oh, and run VAG COM
Not true btw. rotten egg smell is unburnt fuel in your cat. Usually pointing towards a faulty coilpack or spark so 1 specific cylider isn't firing.
mitch2028
76
If all else fails you can take it to midland vw in cannock, he charges 15 quid to plug it in, tell you what the fault is and then delete any if necessary. Not bad really. Ive got a lead but just cant get it to work. Ollie where abouts are you just out of curiousity?
