2footpegs
117
hi i had my LCR remapped with custom code, i have a forge splitter fitted but when i had it remapped the car kept going in to limp mode so i put in full recirc (the car runs SOOOOOOOOOOOOOOOOOOOOO much better) but i was just wondering whether i stil have to worry about the different setting when in the mode or does it not matter. thanks
are you refering to the settings when rotating the rotatable bit at the top? if so having it in recirc or hybrid wont make a difference, so yes! The 'setting' is to adjust the tension on the spring and where you vent to wont effect that.
o okay so i still have to adjust the rotating top for the right spring settin, thats a pain
If it's not clicking when the engine is runing them it's probabley Ok, but it should need adjusting after a remap.
